Old 04-09-2009, 01:01 PM   #1
berencam
berencam's Avatar
Oil guage feed line install question.
Im about to change the line that goes from the engine to oil gauge. Do i need to bleed it and remove the air or will the air not matter. Also what is the reccomended oil pressure for a fresh engine with tight clearances (plastigauged every clearance and they where all in spec but on the tight side), both for idle and for 3-4k rpm. thanks
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-09-2009, 01:35 PM   #2
beautimus
beautimus's Avatar
Re: Oil guage feed line install question.
i wouldn't bleed the oil line, pressure is pressure wheather its oil or air at the end of the line , it doesn't matter.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 04-09-2009, 01:40 PM   #3
berencam
berencam's Avatar
But air compresses, oil doesn't. Seems like it would give a lesser reading.
Old 04-09-2009, 04:02 PM   #4
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
x2 Will not matter if air is in the line or not.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 04-09-2009, 04:23 PM   #5
berencam
berencam's Avatar
ok, and the pressure question?
Old 04-09-2009, 05:34 PM   #6
Green Machine
Green Machine's Avatar
Even if you bleed it air will get in anyway after you shut it off. Say you have 40 psi oil pressure, the air in the line will be compressed to 40 psi also. If you hooked your gauge to an air tank filled to 40 psi, or an oil tank at 40 psi , it still would read 40 psi. The air does not matter at all.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-09-2009, 07:22 PM   #7
Jim_PA
Right. We aren't compressing the oil, just reading the pressure through the line...
Jim_PA is offline   Reply With Quote
Old 04-09-2009, 08:16 PM   #8
68C15
blood type; Retumbo
68C15's Avatar
as for the pressure expected; this an impossible question. granted your bottom end may be good and tight but the important part is the cam bearings. this is where oil pressure is lost or retained.
a general rule of thumb is 10 psi per 1000 rpm. most oil pressure light switches turn on at 7psi.
68C15 is offline   Reply With Quote
Old 04-09-2009, 10:01 PM   #9
berencam
berencam's Avatar
Well im over about double that, at idle(cold) im at 50 4k rpm cold im at 85. Now when the truck has warmed up it will drop to 40ish idle and 70 at 4k rpm. Is this safe operating range?
Old 04-09-2009, 10:35 PM   #10
Green Machine
SBC ? If you used a high volume pump with a high pressure spring, that sounds about right. What is the intended usage ? Personally I like to use a high volume pump with a standard pressure spring, holds great oil pressure at idle without getting too crazy going down the road.
Old 04-09-2009, 10:56 PM   #11
clay68c10
clay68c10's Avatar
That sounds like ok pressure to me, maybe a little high from the tight tolerances.
My BBC holds over 40psi at 2500rpm when hot (rebuild 10k miles ago) and around 20psi at idle.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-09-2009, 11:11 PM   #12
berencam
berencam's Avatar
sbc yes, standard pump also. I also need to change the oil i still have assembly lube in it that i just remembered about. (the engine has less than 2 hours run time on it) That is what could/ probably causing the high reading.
Old 04-10-2009, 05:13 AM   #13
68C15
blood type; Retumbo
68C15's Avatar
you're good to go for pressure. I don't like to have too much volume as it tends to put a bunch of oil up top and leave the pan about empty.
