04-09-2009, 04:21 PM | #1 |
Vibraton
I've got a 87 Sierra Classic and i have a huge vibration in the motor. It is a 350 fuel enject. It has the vibration when it is about 2-3 thousand rpms and when i accelerate. Not sure what the problem could be. If you have any info on what it would be can really help me out.
Thanks |
04-09-2009, 04:50 PM | #2 |
Re: Vibraton
Boy: youve opened a real hornets nest here. 1. it could be anything from a fuel injecter thats dirty to a mismatched piston, also valve train problems, bad plug or wire, you have to check each out, one at a time.
04-09-2009, 05:06 PM | #3 |
Re: Vibraton
The engine runs fine and I just did a whole tune up on the truck and i cleaned out the throttle body. I thought the vibration was the trans mount because the rubber was totally gone on that mount.
04-09-2009, 05:13 PM | #4 |
Re: Vibraton
Maybe a harmonic balancer
04-09-2009, 05:36 PM | #5 |
Re: Vibraton
I was thinking of that or the motor mounts
04-09-2009, 05:53 PM | #6 |
Re: Vibraton
How long ago? When I had my S-10 I changed the plugs & wires but didn't realize till later that one plug wire didn't snap onto the plug the boot just held it in place...sometimes the simplest things are the biggest problems, plus it's a free and quick check. YMMV
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter Last edited by Adams74Chevy; 04-09-2009 at 05:53 PM. |
04-09-2009, 07:44 PM | #7 |
Re: Vibraton
Has anybody had the flywheel off lately? I believe 350's and 4.3's require an internally balanced (engine) flexplate, and other blocks use an externally balanced flexplate/flywheel. However, the wrong flywheels will bolt up.
04-09-2009, 09:53 PM | #8 |
Re: Vibraton
I did it last year in the middle of the summer.Then this year i went and checked it all.
04-10-2009, 07:50 AM | #9 |
Re: Vibraton
Does it do it while your driving or while it's in park and you rev it up?
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
04-10-2009, 08:50 AM | #10 |
Re: Vibraton
yes, when i rev it up it still vibrates.
04-10-2009, 12:02 PM | #11 | |
Re: Vibraton
1987 350 TBI lowered 5/7 |
04-12-2009, 03:37 PM | #12 |
Re: Vibraton
Remove all of the drive belts from the engine and crank it . See if it still does it . If not , it iis in the accessories on the front of the engine . I have seen a bent fan blade cause this and this is how I found it .
Frank
Born and proudly residing in a Red State ! |
04-12-2009, 04:46 PM | #13 |
Re: Vibraton
Thanks Frank i will check that on my next free day.
04-17-2009, 10:22 PM | #14 |
Re: Vibraton
Thanks for all of the input guys. I figure out is something electrical or something not going right in side the motor but prolly something elctrical. It gets better every time i replace or fix something. Thanks again.
87 2wd GMC Sierra Classic. 86 4wd GMC Sierra Classic. 95 2wd GMC Sierra. 96 2wd Chevrolet S-10. |
