Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > 99+ Chevy and GMC Parts Board
Old 04-09-2009, 06:03 PM   #1
Green Machine
Green Machine's Avatar
WTB - Pass side horn - 2001 GMC
Looking for a horn for our 2001 GMC, the passenger side, right side, doesn't work, I think that is the high note one. Might want to send a PM to me if you have something, sometimes I forget to check in here.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-09-2009, 07:01 PM   #2
truckpoorpackrat
Re: WTB - Pass side horn - 2001 GMC
I know i have some I will find them friday & post a picture to confirm which note is correct (the brackets are different from RH to LH .
truckpoorpackrat is offline   Reply With Quote
Old 04-09-2009, 10:39 PM   #3
truckpoorpackrat
Do any of these look correct each bracket is a little different.1st. is a low note, 2nd is low note, 3rd is high. Have more at work, unless they grew legs.
Old 04-09-2009, 10:48 PM   #4
Green Machine
I'll try to take a look tommorow and see what it is, might as well remove it anyway, since it does not work.
Old 04-10-2009, 05:23 PM   #5
Green Machine
Got it off, it is the high note one, looks like the one in the third pic, spiral part is wound the same direction and the bracket looks the same. It has a 2 pin connector. Some numbers from it - AM80 FIAMM E3 35717 CH2035 A 73345. I checked it with an ohmeter, no continuity, so didn't bother hooking it to a battery.
How much to 51334 ? Please test it if you could. I have paypal or whatever works. Thanks.
Old 04-10-2009, 09:31 PM   #6
truckpoorpackrat
Will check to make sure it works in the morning .(found 2 more high note at work but the mounting brackets are different) If its good does $15.00 INCLUDING shipping sound ok. I think shipping will run about $10.00 If ups calculator is correct. Will let you know after I check horn in the morning.
