04-09-2009, 06:29 PM | #1 |
SIR
350 air cleaner...
quick question...how tall of an air cleaner can you put on a 350 chevrolet with a medum rise intake and not hit the hood? thank you....
66long low fleet http://community.webshots.com/user/LVNR66 |
04-09-2009, 06:58 PM | #2 |
Resistance is Futile
Re: 350 air cleaner...
For a while, I ran a 6'' K&N on mine with no problems.....looked Nascar!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-09-2009, 11:25 PM | #3 |
60-66 Nut
I don't think there is an air filter tall enough to be an issue on our trucks. I've seen SBC's with tunnel rams, (running the triangle Edelbrock air cleaners), all under the hood on these trucks.
I'm running a 4" K&N standard base air cleaner on my Burb with a 454.....plenty of room for a taller one.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-09-2009 at 11:29 PM. |
04-10-2009, 09:59 AM | #4 |
283 Drama Queen
And don’t forget the ‘Tin Foil Hat Trick’: Make yourself a wad of aluminum foil and set in on top of your carburator - close the hood - then however much it compresses is your allowable filter space.
Did that on my Chevelle’s motor and picked out the perfect Summit air-cleaner assembly, less the wing-nut (hit the hood) and went with a short chromed fastener instead. Bingo. Mac.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
04-10-2009, 01:16 PM | #5 |
SIR
thank you...
04-10-2009, 02:07 PM | #6 |
What are you going for, SIR?????
