Old 04-09-2009, 08:51 PM   #1
Rudy67chevy
rudy67chevy
Rudy67chevy's Avatar
Disk brake Conversion
I have a 67 c-10 long bed, and want to switch to disk brakes. what other years would fit? besides 71 , 72
Rudy67chevy is offline   Reply With Quote
Old 04-09-2009, 09:23 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Disk brake Conversion
You can swap the whole crossmember from a 71-86? and just drill a couple of holes.You can also do it by using the ball joints to match the spindles from the donor truck.There are quite a few threads on this swap in the FAQ's section which will give you tons of info.You can then best decide what fits you budget/skill set.We're always here to answer questions but there is more info in the FAQ's than anyone can repeat.Swapping spindles also requires swapping tie rod ends.If you're looking to upgrade to PS then a later crossmember may be the ticket.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-09-2009, 09:37 PM   #3
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Just did a 77 front crossmember swap on my daughter's truck . In my opinion this is the way to go drill 2 holes and bolt it in simple . My 2 cents Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 04-09-2009, 10:00 PM   #4
rockdawg
If you do the complete crossmember swap, do you have to take the motor out? Seems like I remember that the perches for the motor mounts are bolted to the crossmember and frame on a 69.
Not trying to hijack a thread... just interested in doing the swap as to what all is involved.
'69 Chevy CST
383 Stroker
TH400
rockdawg is offline   Reply With Quote
Old 04-09-2009, 10:06 PM   #5
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I used the origional motor mounts you will need to drill the hole in the crossmember no big deal .. Bob
Old 04-09-2009, 11:38 PM   #6
Rudy67chevy
rudy67chevy
Thanks everyone.. i have lots of trucks to choose from at work. All take a look tomorrow
Old 04-09-2009, 11:50 PM   #7
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I rebuilt the front end on my 67 about 500km's ago & not wanting to throw away all that cash, I decided to get me some of those drop/conversion spindles that use your old balljoints but that use 71+ disc parts. They are together but I have not put them on yet...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-10-2009, 12:49 AM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
I liked this way as well
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 04-10-2009, 10:04 AM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
so u just used 71spindles and rotors etc
John
1999 Toyota Tacoma 4x4
Old 04-10-2009, 10:59 AM   #10
69ChevyRazorback
Bob is it really that easy??? if you swap out the front crossmember will you have to swap out the rear also? or will the crossmember be the same width as the original????
69ChevyRazorback is offline   Reply With Quote
Old 04-10-2009, 12:42 PM   #11
my67chevytruck
Under Construction
my67chevytruck's Avatar
we used a 72 parts truck and swapped the entire front crossmember and rear end( have pics in my build thread). Typically ppl that do the front crossmember swap either swap the rear end to get the 5-lug or they get the conversion axles that are 5 lug... good luck
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-10-2009, 11:04 PM   #12
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Width is the same I will be using a 72 rear and yes it is easy . The truck is not driving yet but not because of the front I have it tore way apart . If you go to projects and builds and look at Sweet 16 and you can see it with the new front end in it . I think it took me about an hour to bolt in the new front end and drill the holes . I would say it's easy . Bob
Old 04-11-2009, 06:07 PM   #13
69ChevyRazorback
Sweet man thanks for the ideas...
and how much would u expect to spend on a used / junkyard front crossmember with disc brakes????
Old 04-11-2009, 06:43 PM   #14
jablack
Classic Chevy Recycler
jablack's Avatar
I just used the spindles off an 83 chevy truck. You can swap the ball joints and tie rods and you're done. Didn't even touch the cross member.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 04-11-2009, 09:25 PM   #15
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I bought the whole frame for $100 and it came with 15x8 rally's with excellent rings and caps . I took what I wanted and got $25 back for it at the scrap yard !!
Old 04-12-2009, 11:24 PM   #16
69ChevyRazorback
nice man thanks for the info once again. will definately try to do the same for my 69
