question about front anti-sway bar from 73 c10
bought one today but the guy had to cut the brackets from the lower control arm, so I need new bushings and the "C" shaped metal brackets that the bushings fit into.. I measured the bar ends with a caliper and it's 1 1/16" diameter. Does this sounds like a factory size that I can find replacement parts for or is it most likely aftermarket/from another car?
Jonny
Re: question about front anti-sway bar from 73 c10
I pulled that exact same bar froma 85 'burb a couple days ago. The c shaped peices are the same for all sway bars, but the bushings are different for different sized bars.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
didn't think about LMC for some reason before but I just looked there and it appears that 1 1/16" is stock... $40 for the 2 brackets and bushings. Anyone have or know where I can get them cheaper?
Happy to be here
![]() Join Date: Mar 2000
73-87 GM 2wd trucks, Blazers, Burbs...etc will work.
Laid back freak
40.00 is a good price for these.Why would you want to go cheaper? I bought my swaybar off of ebay for 20.00. Had to sandblast it, prime it and paint it.ALso had to buy new frame brackets and all new bushings.By the time i was done i was around 80.00 for everything but it will be well worth it once the truck is on the road:
![]() ![]() thanks pat
1980 chevy c10 step side restomod, ![]() 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). |
#7 | |
Hey that bar looks great. My roll pan is way in the way. Do you know if the front frame crossmember rivit is the one you take out? Put a bolt throught both the crossmember and the sway bar bracket. ?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Word to the wise. Don't buy polyurethane bushings (the red ones) for it. I cannot comment or speculate on polygraphite bushings but the red poly bushings squeak like crap EVEN after greasing them up well
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Read the sway bar FAQ if you have questions. I put the factory GM part number in there for the brackets and also detail the installation including the rivet issue.
Posted via Mobile Device |
i have had my energy suspension black bushings on my 1 1/4" bar for a while now with no noise at all. and i put that bar to work
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
I looked for the biggest i could find...an 8 lug burban 1.25" YEAHHH
#12 | |
#13 | |
If you are having trouble with the squeaks, I use green grease on my sway bar poly bushings on my G8. That takes care of any squeaking from the bushings. |
#14 |
Red ones that don't squeak? What the heck. I've got the greasable ones and I've greased the snot outta them with marine grease (so water puddles don't wash away the grease) and they still squeak like no other. I can't imagine what I'm doing wrong then.
#15 | |
I got lucky, a guy local to me was parting out a C10, and he was very careful to just torch off the rivets, the bushings were even still good so my total investment was $30 plus $5 for bolts. |
#16 |
You can forget the frame brackets and bolt the bushing/bracket directly to the frame.
Did this on my static dropped 74 C10 with 1.25 bar W/poly bushings. Never had a problem and adds ground clearance
#17 |
Would a swaybar off of a 3/4 ton van work?? Found one today at the bone yard.
