Hey fellers
My brake light on the dash stays on. How can I fix it. I crawled underneath the truck but couldn't see no leaks. It stops as good as always. It has drums all around it. I put a new master cylinder on about 5 months ago. So I don't know what is causing the light to stay on! Any help would be a great help.
1967 Chevy C-10 fleetside SB 3speed on column Corvette yellow#35 Black W/Red Metal Flake int. looks like Black cherry Diamond White Pearl /Grille Jenson CD system Wooden bed |
Captain CAAAVVVMMMAAANNN!
did ya check the fluid level in the master cylinder, or the wire that hooks to the prop. valve?
72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas check out the project old yeller |
Just an Old Mr Goodwrench
You may have some air in the system from the M/C replacement, but your problem should have shown up sooner than 5 months - more likely it's the proportioning valve
1969 CST 20 Longhorn 1970 CST 20 Fleetside 1991 Jaguar Sovereign 1992 Mazda Miata |
Has it been on since before the MC change 5 months ago, or is the light a recent thing?
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
I have check the levels. They are o.k. The wire seems to have good connection.
If there is air in the propotion valve. How can I get it out By myself. The light is a recent thing. How hard is it to replace the p/v.
member #16
![]() Join Date: Dec 1999
If it is the p/v the light should go out when you unhook the wire. I would bleed the brakes again and see if the valve centers itself.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
![]() Join Date: Jul 2000
Try pushing on brake pedal hard (approx. 100 lbs ) this should reset piston in proportioning valve which is probably causing light to stay on.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I had the same problem. Good brakes but the light stayed on. I replaced the sensor that the wire goes to with one from a parts truck and that fixed the problem. The light now comes on when I start the truck then goes out. Andrew
'67 Chevy Longbed Fleetside - Daily Driver(For Now) '72 Cheyene Longbed Fleetside-Daily Driver Best Towing Service |
![]() Join Date: Jan 2001
I had the same thing with the light. I thought there had been no fluid loss, but when I pulled the drums I found a bad wheel cylinder. Just leaked enough apparently for the light to come on.
Bernie |
Spank 'em if you got 'em!
My breaks were horrible and the only time my light came on was when my emergency break pedel slipped down.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
![]() ![]() Well I pushed the pedal real hard and real quick. Then unpluged the wire . Then pluged it back up. The light went out. Now it comes on when I start the truck then it goesout . Like it is supposed to do. But as soon as I can get in the garage. I will check the wheel cylinders again. For any leaks. Once again "THANKS FOR ALL HELP" I couldn't do with out you guys. redneck_chev
