Old 04-10-2009, 12:53 AM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
Should I do it
I'm thinking about raising the back of my truck a little bit by adding a couple leaf springs back, right now it has a flip kit and 5 out 8 leafs removed including the over load, it has a little rake now but its the camera angle, but I think it needs a little more
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-10-2009, 01:02 AM   #2
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: Should I do it
Is all that lawn equipment getting too heavy?
I would put larger tires back there, but yeah I know what your talkin bout, rake is good.
heavychevy79 is offline   Reply With Quote
Old 04-10-2009, 01:24 AM   #3
sswitzke
sswitzke's Avatar
Re: Should I do it
nothing wrong with a little rake.
1967 Chevy long bed
1966 Chevy short stepside
sswitzke is offline   Reply With Quote
Old 04-10-2009, 02:01 AM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Should I do it
remember that the rear wheel opening is actually lower than the front one... I think it looks good as is.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-10-2009, 02:10 AM   #5
flamingbig10
6.0 powered square
Re: Should I do it
the lawn equipment not a problem since all the stuff weighs less than 50 pounds that I'm using now, its has over a Inch taller tire in the back maybe a 31 will do it , just any thing heaver hit the c-notch
Aaron
Old 04-10-2009, 02:13 AM   #6
flamingbig10
6.0 powered square
Re: Should I do it
I remember, thanks I might leave and just add helper bags and use them when there needed, least the stance looks better than it did when it was lowered about 4-9 or so
Aaron
Old 04-11-2009, 10:34 AM   #7
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Should I do it
In your case I wouldnt go with a bigger tire to get more rake. I would add what ever it takes to raise it 1/2-3/4"... get the distance from front to back the same (tire/rim to fender lip).
CLASSIC87' is offline   Reply With Quote
Old 04-11-2009, 01:25 PM   #8
JohnC
JohnC's Avatar
Re: Should I do it
Yeah I think I would add a leaf back to see what it did. I like the rake look.
JohnC is offline   Reply With Quote
Old 04-11-2009, 02:20 PM   #9
Manbearpig
Manbearpig's Avatar
Re: Should I do it
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 04-12-2009, 12:33 PM   #10
flamingbig10
6.0 powered square
Re: Should I do it
I might try some lift shackles http://store.summitracing.com/partde...5&autoview=sku, since I have no idea were the leafs that I took off went to
Aaron
Old 04-12-2009, 12:34 PM   #11
flamingbig10
6.0 powered square
Re: Should I do it
the cowboy hat and rake
Aaron
Old 04-12-2009, 03:07 PM   #12
Manbearpig
Manbearpig's Avatar
Re: Should I do it
Texas rake
1972 GMC C10
Old 04-12-2009, 03:42 PM   #13
78 Chevyrado
Re: Should I do it
That would make a great avatar...haha
78 Chevyrado is offline   Reply With Quote
