04-10-2009, 01:03 AM | #1 |
ram air ?
do they make a ram air kit for a 79 c10 ? if so were can i find one at ?
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final." Hunter S THompson |
04-10-2009, 01:06 AM | #2 |
Right on the line, baby!
Re: ram air ?
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
04-14-2009, 10:27 PM | #3 |
Re: ram air ?
I made mine its an 88 crew cab and yes thats 4" pipe
on the 81-91 core support they have 4" holes on each side of the radiator. I went and looked at a 70 somethings core support and it looks like you could blow a hole in it.
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
04-14-2009, 10:46 PM | #4 |
BAD BOW-Silverado XST
Re: ram air ?
04-15-2009, 01:30 AM | #5 |
Re: ram air ?
where do you guys buy your air box ?
my c10 has 1 hole on one side of the radiator the other is cover .
04-15-2009, 08:40 AM | #6 |
Re: ram air ?
Look at Philatruck's post. It is a pretty inexpensive route, and it looks good too!
04-15-2009, 09:55 AM | #7 |
Re: ram air ?
04-15-2009, 10:40 AM | #8 |
Re: ram air ?
Mine have had holes on both sides. I've cut/ or removed the cover from the front part on the factory setup and the baffle in the air cleaner in the past. Technically, that is ram air--and nothing is cheaper.
gchemist--I likey.
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd Last edited by jdurant; 04-15-2009 at 10:44 AM. |
04-15-2009, 10:48 AM | #9 |
Right in front of you.
Re: ram air ?
My truck has the RamAir air cleaner box....the ducting and mounts at the core support are from the local hardware store. Dryer ducting.
04-15-2009, 10:52 AM | #10 |
Re: ram air ?
04-15-2009, 10:57 AM | #11 |
Re: ram air ?
04-15-2009, 03:16 PM | #12 |
Cruzzzn' Vet
Re: ram air ?
Slick set up do you have a small filter in the Plenum on top of the carb
04-15-2009, 04:36 PM | #13 |
Re: ram air ?
04-15-2009, 04:53 PM | #14 |
Re: ram air ?
malo83 yes that has a filter in it there I'M thinking about reenginering it
04-15-2009, 09:42 PM | #15 | |
Re: ram air ?
Rogue: I went to the bone yard and got the second baffle. Now I may remove it anyway. Or drill it.
04-16-2009, 09:07 PM | #16 |
Re: ram air ?
Wait until you see it in person. Texas needs a gathering!!
04-17-2009, 12:07 AM | #17 |
Re: ram air ?
Agreed. I'm down for a meet. Although right now, at this moment, the only square I've got that runs is real busted up on one side. I've been looking for a reason to get to Austin (I'm a wierdo myself). I'm sure I'll find a reason this summer. I'll let you know.
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd |
04-17-2009, 01:35 AM | #18 |
Re: ram air ?
It may look nice, but I've always thought that actual power from this was something of a myth.
Not just the ram part (insinuating that there's some sort of turbo effect) but the colder outside air on a street engine won't produce a noticeable difference in power. I'm not much for adding things that could fall off w/o a real advantage. Then again, mine's a 4x4, so not much can help in performance. Any thoughts? |
04-17-2009, 08:25 PM | #19 |
Re: ram air ?
Who said I'm running a street engine? Okay, just kidding.
The ram effect only happens at inconveniently high speeds, but the increased density of colder air, the increased mass of a given volume, increases engine output. If you want proof, look a drag times at high altitude. Heck, I noticed a difference in higher RPM power when I flipped air box lid.
