Old 04-10-2009, 06:44 AM   #1
aboz
aboz's Avatar
Removing the dashboard
Can someone please tell me how to remove a 60-63 dashboard!? I removed all the bolts I can find and it still wont budge. Do I have to remove the windshield? Pry off the A pillar covers? What!? Help!
ABOZ
aboz is offline   Reply With Quote
Old 04-10-2009, 07:58 AM   #2
orange66fleet
Lowered in Cleveland
Re: Removing the dashboard
I just removed the dash from my 63 I am scraping out and there was 3 bolts on each side, the with the windshied removed, drill out all spot welds, then the pillers need to be removed, because there is a bracket that is spot welded behind the piller. I will try to get pictures for you.
orange66fleet is offline   Reply With Quote
Old 04-10-2009, 09:46 AM   #3
daverod
SSN 706
daverod's Avatar
If your thinking about sticking in a different dash just cut it out along the windshield leaving about a 1". Then when you put in your new dash just weld it on top of the lip. If you going to stick the same year or model back in then just drill out all the spot welds.
daverod is offline   Reply With Quote
Old 04-10-2009, 11:19 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Before you cut the welds, stop and think. The dash is a pain to get back in correctly. If it has major damage, rust or you're customizing, go ahead. If you need to make minor repairs, like fixing a hacked radio hole, repair it in place. Cut & weld, hammer and dolly, or whatever needs done.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-10-2009, 11:23 AM   #5
joe231
joe231's Avatar
with Fred
What are you trying to accomplish?
CHEVY ONLY
