04-10-2009, 10:52 AM | #1 |
Grandpa in the rustmobile...
will everything from my 72 disc go onto my 68 drum without buying anything else?
okay well were outta school for next 3 days..can i pull my booster mc off my 72 gmc and will they bolt right up to the firewall on the 68?
and so i need any specialty tools to pull the spindles off the 72 gmc and the spindles/all balljoints/tierod ends will go onto my 68 basically i wanna do a disc swap on the front and dont know if i need to buy anything and if im up for it thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-10-2009, 12:15 PM | #2 |
Re: will everything from my 72 disc go onto my 68 drum without buying anything else?
Easiest way would be to swap the entire front cross member. The upper arms are slightly different between drum & disc front end. Ehere the lines hook up. Other than that I think everything else will easily wasp over. But to do it right take everything from the later model and put on the 68.
and yes the swap the booster, proportioning vale and all from the 72 over to the 68
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 04-10-2009 at 12:17 PM. |
04-10-2009, 01:02 PM | #3 |
youll also need to swap the front brake lines if you dont want to buy new ones, and yes the booster will bolt right up but be sure and use the longer push rod tht bolts to the brake pedal assy.
1967custom Last edited by michael bustamante; 04-10-2009 at 01:02 PM. |
04-10-2009, 05:29 PM | #4 |
Thank you, that was the one thing I forgot about for the swap.
04-10-2009, 05:38 PM | #5 |
the longer push rod from the 72?
step 1: take booster/mc off 72 step 2: put mc booster on 68 step 3: take spindle assembly off 72 step 4: put spindle ass. on 68 step 5: put ?NEW? lines on 68, what lines do i get?
04-10-2009, 05:47 PM | #6 | |
Get lines for a 72,
04-10-2009, 05:51 PM | #7 |
ok i want front brake lines for a 1972 1/2 ton 2wd chevy truck
getttin this rite cuz autozone konws nothing if its not on the puter lol
04-11-2009, 01:51 PM | #8 |
right. also very important use the prop. valve from ther 72 also. otherwise nothing will work right.
1967custom |
04-11-2009, 02:04 PM | #9 |
If I remember right, the lower ball joints and outer tie rods on the 67-69 trucks will not work correctly with the 71-72 spindles. You will also need the front brake hoses. I'd recommend new ones (I actually recommend new "everything"). If you use the 67-69 lower control arms you will need to trim the "tit" on the spindle or you will not get a full lock to lock turning radius. You'll see what I mean once you get everything installed. Grind slowly and check the lock to lock turn often.
It really is "better" to just swap the whole damn thing
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-11-2009 at 02:07 PM. |
04-11-2009, 02:12 PM | #10 |
resident oilfield trash
If your going to have the ball joints out any way you should really just buy new ones
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
04-11-2009, 10:08 PM | #11 |
swap the whole thing, you mean swap the a arms and all?
cuz im not pullin the motor so the whole crossmember swap is out
04-11-2009, 10:46 PM | #12 |
WTB this ad
I think the reason that they're suggesting swapping the entire crossmember is that when you just swap the spindles your track width gets wider. If you put the entire crossmember from the disc truck under it you shouldn't have an issue. I'm also pretty sure that 71-72 spindles will fit the ball joints and tie rods of trucks from the early 60's through 70. (My old spindles from the C10 are currently rolling on a 64 pickup). The problem is when you try to put 73 and up spindles on a 70 or older pickup. I'm pretty sure that is when you're going to have ball joint/tie rod issues. A slightly wider track width shouldn't be to much of an issue unless you plan on lowering your truck.
Disclaimer: I've never converted one from drums to discs! I do know people that have. It made their track width wider and caused their tires to scrub when lowered. That's where we got the front springs for my brothers drop we just did. Swapped a set of stockers back in for a buddy to keep from eating up his tires with the fenders. |
04-11-2009, 11:24 PM | #13 |
Ok guys I'm wanting to take a 1978 cross member with discs and put on my 1969 c10 will this work the same as oldblue 68's swap!
04-11-2009, 11:33 PM | #14 |
I thought the upper ball joints were the same, but LMC is listing a different part number for upper ball joints as well. According to LMC (I checked the advance site too) they list different part #'s for the upper and lower ball joints and tie rod ends for 67-70 trucks and 71-72 trucks. Whether they are actually different or not, I do not know, but two different sources list different part #'s.
My truck was such a mix and match. I used an entire set up off of a 71 GMC I pulled from a yard, the complete suspension, brake lines, power booster, prop valve, and steering box, but after I got the mud pressure washed off the suspension I found the PS lower A-arm had some damage (looks like they hit a stump with it?) so I had to swap my 67-69 Arms, that's how I know about the spindle tit. The steering bump stops are different. When I rebuilt the suspension, I asked for "all 72" parts when I bought everything. That's nice to know about the cross member, I never knew that was the reason behind the suspensions sticking out on some trucks and not others. I'm really glad I swapped the whole cross member then! Guess we'll need some more confirmation on whether or not the parts interchange.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-11-2009 at 11:36 PM. |
04-12-2009, 12:58 PM | #15 |
im still in the dark lol
