![]() Join Date: Oct 2008
Can you change rear from 6 lug to 5 lug without buying rear disc brake kit?
I am planning to put disc brakes on the front of my 69 and I would like to go to 5 lug due to more wheel options. How do I change the rear from 6 lug to 5 lug without buying a 700$ rear disc brake kit??? (and this is probably a dumb question but im young and inexperienced when it comes to restorations
![]() thanks guys. |
Re: Can you change rear from 6 lug to 5 lug without buying rear disc brake kit?
ok i just found an axle conversion kit for 400 dollars....any other cheaper options?
Grandpa in the rustmobile...
free bump i wana no too think you can swap a whole rearend out but may be rong
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
ive converted mine to disk/drum on mt 69 just took a rear end out of a 71-71 half ton and bolted it up with brakes u use the front more so the rear drums will last for a long time
i don't know if i got lucky or what but i found a mid 70's and the axle swapped right out less than 50 dollars
yes width was same and was 5x5 but all i changed was axles. however double check cause i know sometimes the brake drums wont go on right if the axle length is different
![]() ![]() Join Date: Jul 2002
On 69 and earlier (actually around mid 1970), the axle is narrower by 3/4" on each side, so an axle swap may not be the best choice. However, a direct bolt in would be a 71/72 rear end assembly. You can also use a 73-87 rear end, but you'll have to move the leaf mounts (if you have a leaf spring rear) or cut off the leaf mounts and but the mouts for the coil spring rear.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 04-10-2009 at 12:05 PM. |
BOHICA
Moser can redrill your axles and drums for about half that.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
thats all did is take the whole rear end assembly and mounted it and correction (71-72 half ton) sorry
cool so just any coil spring 71 72 bolts right into a 67-70
Yep, any 1/2 ton will give you what you want.
#13 |
Tot Roddin'
Just make sure to look at your entire project from start to finish. If you ever plan on running a large dia. set of wheels you might like being able to run more BS on the rears and opt to keep the 67-mid 69 rear end.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#14 |
I did some machining to my 69 6 lug axles long ago to make them 5 bolt pattern. Now I found out one axle is shot. Anyway, I want to know if anyone has tried to use 5 bolt axles from a mid 70's chevy 1/2 ton with any success. I know one guy on this forum said he did but others disagree. If there is a difference in the axles does anyone know exactly what the differences are? I'd like some advice before I start ripping a bunch a rear ends apart.
81 Blazer 69 C-10 |
#15 |
I believe the axles are different. Check out the CPP catalog, they sell a conversion kit that may help explain the difference in axles.
#16 |
How about 6 lug to 5 lug wheel adapters
#17 | |
![]() Join Date: Dec 2008
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
#18 |
Thanks all. I just decided to have a machinist repair the axles. For some reason the farmer before me or before him ground down the ends. There was too much play in and out as a result. I had to have them built back up again and ground smooth.
81 Blazer 69 C-10 |
