Old 04-10-2009, 01:17 PM   #1
sidthirteen
sidthirteen's Avatar
fuel gauge question
Hey everybody!! I'm trying to get my fuel gauge to work but something doesn't look right. I had connected the new wire to the fuel tank and saw a grounding wire that looks kind of odd. My question is, isn't there supposed to be a resistor of some kind? Here are some pics...... thanks in advance.
sidthirteen is offline   Reply With Quote
Old 04-10-2009, 01:27 PM   #2
Joemomma1
Joemomma1's Avatar
Re: fuel gauge question
Thats how mine looks. Have you checked the float?
Joemomma1 is offline   Reply With Quote
Old 04-10-2009, 01:44 PM   #3
sidthirteen
No, I haven't. Does your gauge work like that? Just need to make sure I'm not missing anything...
Old 04-10-2009, 02:02 PM   #4
Joemomma1
Joemomma1's Avatar
Works great. I had a hole in the original float that caused it to fill w/ gas keeping it down.
Old 04-10-2009, 02:06 PM   #5
19GMC63
19GMC63's Avatar
do you have a multimeter that can measure resistance?
19GMC63 is offline   Reply With Quote
Old 04-10-2009, 02:09 PM   #6
protrash64
Resistance is Futile
protrash64's Avatar
The variable resistor is in the tank.....you cant see it unless you remove the float assembly.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-10-2009, 02:12 PM   #7
sidthirteen
yeah, I checked and got 1.5ohms
Old 04-10-2009, 02:13 PM   #8
sidthirteen
I see.. Thanks for the info.
Old 04-10-2009, 02:14 PM   #9
sidthirteen
Cool.. Thanks!
Old 04-10-2009, 02:27 PM   #10
chucks1967
The problem with mine was the copper strap running from the variable resister to the connector on the outside. It was broken right in half. I removed mine and braised the two halves back together. Its not hard and its free. just make sure that you have dried it out really good before applying any flame as you know it contains gas. and gas + flame = boom. here is a pic of a new one out of the tank.. but as mentioned above check the float, and the resistance of the resister as you move the float level.
chucks1967 is offline   Reply With Quote
Old 04-10-2009, 02:35 PM   #11
sidthirteen
Sounds good! Thanks for the info!
Old 04-10-2009, 03:32 PM   #12
19GMC63
19GMC63's Avatar
Like chuck said, just double check that the range (0 empty, 30 full) is good. Verify 12 volts at the gauge... also make sure your grounds are good, especially at the gauge. Don't know how chevys are, but I had to run a separate ground wire for the printed circuit since my painless harness did away with it, but again, that's just dependent on your set up.
Old 04-10-2009, 05:32 PM   #13
sidthirteen
Right on... I'll check it out this weekend. Thanks a bunch!!
Old 04-10-2009, 07:22 PM   #14
protrash64
protrash64's Avatar
I just fixed mine in the 'burb, sidthirteen. At the gauge you should have a 12v source on a pink wire, then tan leaving to the fuse block, eventually. It wraps around a bit, but gets there eventually......anyway, then a tan wire plugged in to the fuse block which then heads out to the tank. The sender is then grounded to the frame/body.
Old 04-10-2009, 08:35 PM   #15
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Mine reads full all the time.
Any suggestions?
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 04-10-2009, 08:59 PM   #16
19GMC63
19GMC63's Avatar
With everything working fine, taking the tan wire off the sending unit will cause the gauge to read past full, so you may have a bad connection at the sending unit, or a break in the tan wire somewhere.
Old 04-10-2009, 10:50 PM   #17
protrash64
protrash64's Avatar
Any suggestions?
I had the same issue retodd.......and after re-doing my tank with a new sender and new wiring (ground) it was still full. The gauge was supplied with 12v from dash harness. What I found was a connector unplugged that goes on the steering column. This broke the continuity between the gauge and the fuse block. Once plugged in it worked just fine. Sometimes I have seen people mention that the tan wire to the the fuse block is unplugged. Check out your fuse block, there is a place labeled 'fuel' I believe....this is where the tank wire plugs in to the dash harness.
