04-10-2009, 01:50 PM | #1 |
Formerly- 1972SuperCheyenne
Brake Line Help
I bought the full 11 peice set of stainless lines for my 72 Cheyenne Super project. However, when I bought this truck all the lines had been removed for the frame to be cleaned, painted, etc... So, I really could use some good pictures of where and how these lines run so I can get them installed properly. I also bought the set of clips and retainers so that should help too. If anyone could help I would really appreciate it. Thanks--Josh
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
04-10-2009, 04:08 PM | #2 |
Restoring it $200 at a time...
Re: Brake Line Help
Don't know if I'll get pics this weekend, but....
Two hard lines down from the MC quite close to the headers. (After 10 years of owner inattention, one steel line rubbed thru, prompting my upgrade to SS. ) Both across the back side of the cradle to the pass frame rail. One forward to the RF wheel, one backwards alongside the fuel line IIRC, the rear line kind of wraps around the RR shock, then goes up to a tee on top of the diff. The hard lines to each rear wheel stay above the axle tube.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 Last edited by hounddogs!; 04-10-2009 at 04:09 PM. |
04-10-2009, 04:21 PM | #3 |
Re: Brake Line Help
bump would like to know too!!
04-10-2009, 09:31 PM | #4 |
Re: Brake Line Help
More pics coming...
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
04-10-2009, 09:37 PM | #5 |
Re: Brake Line Help
RF shock in first pic. The brake line is on the bottom in the middle pic. Bottom pic is the RR shock.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 Last edited by hounddogs!; 04-10-2009 at 09:38 PM. |
04-10-2009, 09:42 PM | #6 |
Re: Brake Line Help
Going from right to left...
04-11-2009, 01:52 AM | #7 |
Re: Brake Line Help
ttt more more more lol
04-11-2009, 01:16 PM | #8 |
Re: Brake Line Help
Thanks for the pics. However, that is not like mine at all. Is that a drum, drum truck? TTT
04-11-2009, 04:27 PM | #9 |
Re: Brake Line Help
C20 with drum-drum.
04-13-2009, 07:58 AM | #10 |
Re: Brake Line Help
Anyone else? Could really use some help here fellas.
04-13-2009, 11:21 PM | #11 |
Burnouts are therapeutic
Re: Brake Line Help
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=151 heres a link to lmc's diagram should help if you don't already have it figured out
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
04-14-2009, 12:20 AM | #12 |
2WD Jimmy
Re: Brake Line Help
The front lines Should run the same. That is, along the back of the front cross member, and the rear runs from there along the inside of the passenger side frame rail to the middle of the crossmember that is just in front of the duifferential. From there it jumps via a single flexible line to a the top of the diff.
04-14-2009, 07:46 AM | #13 |
Re: Brake Line Help
Thanks guys. Got iy all figured out yesterday while everything was slow here at the shop.
