04-10-2009, 11:01 PM | #1 |
Saving 1 truck at a time!
Big Block vs. Small Block Springs
Who has replaced their 3/4 ton front springs with big block springs to see how much the front end will come up? I want to raise the front of my small block truck a little...not much...just trying to get it level...ON THE CHEAP...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 04-10-2009 at 11:02 PM. |
04-11-2009, 12:56 AM | #2 |
Re: Big Block vs. Small Block Springs
Can't speak to your question exactly but I put a BB in my truck with SB springs and then later put in the BB springs. Less than 1/2" change and I would have to believe that most of that was because of going from the old original springs to new springs.
04-11-2009, 01:52 AM | #3 |
Dang...I was hoping for alot more than that...but 1/2" is good just the same.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
04-11-2009, 04:48 AM | #4 |
I think the 3/4 springs and bb springs are the same or very close but you will prob gain some just replacing old with new.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
04-11-2009, 01:44 PM | #5 |
These are Rancho springs however they are the same as bb springs.
www.cardomain.com/id/pooz911 |
04-11-2009, 02:01 PM | #6 |
I have 1 inch upper ball joint spacer installed, limiting straps, longer shock absorbers. and a little trimming of the crossmember to help with the upper control arm clearance.
www.cardomain.com/id/pooz911 Last edited by pooz911; 04-11-2009 at 02:02 PM. |
04-11-2009, 02:04 PM | #7 |
I believe the spring rates are different between sbc and bbc springs. The spring rate in the bbc springs give you the lift.
04-11-2009, 04:07 PM | #8 |
Where did you get the upper ball joint spacer? That should add about 1" too.
04-13-2009, 10:36 PM | #9 |
The upper ball joint spacer does not add any lift on the truck. All it does is decrease the ball joint angle and makes it possible to align the front end.
