Old 04-11-2009, 03:38 PM   #1
mothertrucker424
mothertrucker424's Avatar
leaf mixing
i have 2 sets of 4" lift springs for my 72 can i take them apart and add them together or can i get another set of leaves and add to my 4" lift i plan to run a 36" tire so i am looking for 6-8" of lift and in rear can i just add a add a leaf
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 04-11-2009, 04:44 PM   #2
LONGHAIR
Re: leaf mixing
Adding an excessive amount of leaves to the springs just makes them stiffer. The ride suffers and off road suspension travel is limited. You need more arch to the springs to ride higher not just thickness of the pack.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-11-2009, 06:03 PM   #3
mothertrucker424
Re: leaf mixing
will a add a leaf help?
Old 04-12-2009, 01:36 AM   #4
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
Re: leaf mixing
to keep it safe and relatively comfortable, all you can do in the front with 4" lift springs is a zero-rate and a longer shackle. with a 1" zero-rate and a 2" longer shackle, you technically get 2" more of lift in front. with that zero-rate, you'll be able to move your front axle forward 1 1/2" to fit a bigger tire with less lift though.
bmeredith is offline   Reply With Quote
Old 04-12-2009, 10:28 AM   #5
LONGHAIR
Re: leaf mixing
Longer shackles on the front can/will effect the caster of the wheels and the angle of the front driveshaft.......I am not a fan
Old 04-12-2009, 11:42 AM   #6
justcuz
justcuz's Avatar
Re: leaf mixing
I've mixed and matched and rebuilt springs lots of times. You won't get a lot of lift, more to change the spring rate. The ones I did usually gave me no more than an inch or two lift. Keep the leaf material the same thickness. Try to keep your shortest leaf no shorter than 18" test them out for ride. Then take them to a good spring shop and have them re-arch them two inches over stock. This process will give you a solid three inches of lift...after the springs settle.
justcuz is offline   Reply With Quote
Old 04-12-2009, 05:09 PM   #7
onlyifihadachevy
Re: leaf mixing
wow, i have some weird stuff but that takes it, an adjustable block.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 04-12-2009, 06:20 PM   #8
mothertrucker424
Re: leaf mixing
thats all a zero rate is right i could just do 1"-2" worth right or is that unsafe i understand that 12" of cut leaves is un safe
and i may just take my 2nd spring pack and have them re arch it what do i tell them?
Old 04-13-2009, 01:14 AM   #9
justcuz
justcuz's Avatar
Re: leaf mixing
Just tell them you want them re-arched 2 inches over stock. You don't want to go much more than that. Highly arched springs do not flex well and ride horrible.
