![]() Join Date: Mar 2009
Hey guys i'm new here and im working on a 69 stepside rebuild and i need help. Can you take a 1978 front end with disc brakes and unbolt it from the frame and bolt it up to a 1969 frame ?
Resistance is Futile
Re: disc brake exchange
Yes. with minor drilling, or just use the control arms if you do not want to pull the engine.....not sure about all the steering components, but it will work.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
The engines are pulled on both . Just bare frames with cabs. Thanks for the information .
The steering stuff will all work....its the idler arm that may need some type of screwing around with to get it right. Im assuming both have power steering, too.
Happy to be here
![]() Join Date: Mar 2000
You will need to do a bit of tweaking on the brake lines to, but nothing major.
