Old 04-11-2009, 07:47 PM   #1
abilityonline
68 C-50 4+2 Spd Trans question
Picked up a 68 C50 Dump from a foreclosure. I've got the Dump working great and got the brakes good to go. I took it for a spin and I'm not clear how the 4+2 Spd trans works. It has a knob on the gear shift that I can pull in or out. Can anyone explain how this works and how I should use it properly?
abilityonline is offline   Reply With Quote
Old 04-11-2009, 07:52 PM   #2
chas350
Re: 68 C-50 4+2 Spd Trans question
I believe that is a 2 speed axle, when carrying a load one would pop that in and out when shifting. IE: 1st gear low, 1st gear high, 2nd gear low, 2nd gear high, 3rd gear low, 3rd gear high and so on as load/speed/road conditiond vary.
chas
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 04-11-2009, 10:55 PM   #3
mvfd70
mvfd70's Avatar
You are correct. That would be a 2 speed axle. They are a LITTLE different to drive. It's not like it has 8 gears. You don't really need to shift the axle all the time Example: 1 low to 1 high to 2 low to 2 high to 3 low to three high to 4 low to 4 high. Hope that makes sense.
Some of the gears will "cross" each other. Depends on the gear ratios. Example: 2nd gear high might be geared higher than 3rd gear low.
I've never driven a chevy with a split rear end but some others I've driven you have to clutch to change from low to high or back to low. Others will shift up without clutching but not back down unless you clutch.
This all sounds confusing doesn't it? Well its not really that bed. Best thing to do is take it out and play around with it. You'll figure it out. If I thoroughly confused you let me know.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 04-11-2009, 11:15 PM   #4
The knob activates a solenoid on the center section of the axle.What goes on inside there is a mystery to me.
Old 04-12-2009, 10:19 AM   #5
Wrenchbender Ret
The shifter inside the diff. is spring loaded. You always have your foot on the gas when you pull/push the button. To upshift pull up on the button, let off the gas till the engine slows down to the speed it will be going after the shift & you will fell a jerk or clunk. Then press on the gas & it should be in the higher gear. To downshift press the button down, let up on the gas & get back on it. When the engine speeds up to the lower gear it will engauge & start pulling. You can use the clutch but it works smoother without it. Split shifting is another lesson.
Wrenchbender Ret is offline   Reply With Quote
Old 04-12-2009, 02:13 PM   #6
abilityonline
excellent replies thanks a ton. All I have left is getting a bunch of little electrical stuff going again, Wipers, washer fluid, blinkers, brake lights .... Then we are good for inspection and ready for the road.
Old 04-12-2009, 07:28 PM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
I've driven a bunch of 5+2 trucks, its easy to drive, but not easy to explain to someone over the internet.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
