Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-12-2009, 08:21 AM   #1
tubbed55
tubbed55's Avatar
Will intake still work
Was checking catalogs today getting part #'s for everything I neeed. Noticed two different intake gaskets for rectangle ports with or without upper bolts. This is my first set of rect port heads and did not know there was a difference. After looking, my heads do not have the upper bolts, but my intake does. Can I still use the intake manifold. If so do I need to do anything special?
tubbed55 is offline   Reply With Quote
Old 05-05-2009, 08:18 AM   #2
larry may
Re: Will intake still work
post picture's of what you are using does not like a yes no question with out more information. Pics are worth many words
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 05-05-2009, 11:05 AM   #3
71Dragtruck
71Dragtruck's Avatar
If your talking the 4 bolts in the center of the runners then yes you should be fine. Alot of larger single plane manifolds such as the Victor jr. don't have those holes and your aftermarket heads are likely set up for one of those manifolds. A better question would be are the heads too big for your application if your building a motor around a lower flowing intake (I assume because it has those bolts) and what about the cam and compression, can they support those heads?
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
