Question about a part name.
What is the nut called that holds the arm that goes transmission linkage to the shifter called. I cracked mine and I need to get new one.
Re: Question about a part name.
Is this the nut that is on the transmission itself?
If it is then it is a 3/8 fine thread nut. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
It's on top of bar that goes from trans up by master cylinder. It has a loop that bar goes though and when tighten the nut it hold the bar in place.
The Older Generation
I don't know if it is called an adjuster or not but you use them to adjust the length of the shifter rods. LockDoc
Do you just need the nut or do you need the whole piece? I think that nut is a lock nut but I'll have to check the manual when I get home.
its all about the +6 inches
You'd be best off goin to a junk yard, you'll probably never locate it on it's own.
Vans are a great place to look for it, they used that up untill 81/early 82. |
Don`t you want the "whole" name?Sorry,couldn`t help myself.
If you only need the nut it is a 3/16-16 standard nut which would be available at your local hardware store.
Here is a picture of the assembly.
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 07-14-2009 at 12:52 PM. |
I over tightened and broke it. That's why my brother inlaw calls me gorrilla
