04-12-2009, 07:43 PM | #1 |
Is this right?
I got this 69 frame in and had this crossmember and carrier bearing set up... is this right or ???????? got factory rivets
Lowered 2002 PT Cruiser ONLY for mileage. 1969 Stepside 4x4 ( under construction ) |
04-12-2009, 10:17 PM | #2 |
its all about the +6 inches
Re: Is this right?
movin to the 4X4 page, they'll probably know
04-13-2009, 01:05 AM | #3 |
Re: Is this right?
I have seen the cross member with the skid plate but not sure about what that is under it.
04-13-2009, 10:53 AM | #4 |
Member #1049
Re: Is this right?
Are you sure its a 69 frame? My 68 GMC 3/4 ton 4X4 longbox frame that came with the Rockwell T221 transfer case had that crossmember with a 2 piece driveline.
I have only seen that setup in 67 and 68 long box and Suburban 4X4s.. One way to identify it is look at the front spring perch/radiator core support bracket.. 67/68s have a cast iron spring perch riveted to a stamped steel core support bracket.. all 69 - 72's it was all stamped steel.. Plus, only 67/68 used 3" wide springs instead of 2.5" |
04-13-2009, 11:01 PM | #5 |
Re: Is this right?
I bought a K10 new in 1969 had a rockwell transfer case, two piece drive shaft with center support and the crossmember like yours. I would say that is definitely factory.
04-14-2009, 09:32 AM | #6 |
I'm a poor spectator
Re: Is this right?
Didn't they also come with dana 20's?? I've never seen the mount for one so I couldn't tell you but maybe it's something to consider. I think the dana 20 was only offered in I6 trucks with a manual tranny but I might be wrong.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 04-14-2009 at 09:32 AM. |
04-16-2009, 09:11 AM | #7 |
Born Psycho
Re: Is this right?
definitly a factory setup. 69 was the last year that was used. the rockwell t-case was dropped in favor of the 205 in 70--in trucks, not sure about blazers.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-16-2009, 04:56 PM | #8 |
Post Whore
Re: Is this right?
Same as my 69 K20's setup also.
Oh, yours is upside down also
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 04-16-2009 at 04:56 PM. |
