Old 04-12-2009, 09:03 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Removing 700R4 Shifter Rod
I am trying to remove the shifter rod in my 700R4 tranny. I removed the manual detent spring, 5/8 nut off the shifter rod and the shaft retainer. I just cant get the inside detent lever to seperate off of the shifter shaft. Any ideas??
1971ChevyTruck is offline   Reply With Quote
Old 04-12-2009, 09:22 PM   #2
cdowns
cdowns's Avatar
Re: Removing 700R4 Shifter Rod
wack it gently wth a hammer
Old 04-12-2009, 09:39 PM   #3
1971ChevyTruck
I tried to put a set of vise grips on the outside portion of the shaft and tap it out, but it never moved
Old 04-13-2009, 04:21 PM   #4
1971ChevyTruck
Mission Complete!!
Old 04-19-2009, 02:29 PM   #5
1971ChevyTruck
Well it is installed, but now a new problem. The new shifter lever didn't have a nut on it. I bought both a fine threaded nut and course nut and neither will start on this shaft. Is there anything special about these shafts? Anyone know the pitch of the threads?
Old 04-19-2009, 02:43 PM   #6
1971ChevyTruck
I think I just found my answer...I think its a 10mm 1.5 nut. Am I right??
