Old 04-12-2009, 10:09 PM   #1
ap2002
who still uses a thermostat?
who here still uses thermostats on there motors? i know a long time ago when my dad always took off the thermostats on his engines, he said ever since he broke down on the highway 300miles away from home, he just takes them off on the older vehicles... he never had issues without one... so what are the pro's and con's of NOT running a thermostat...
by the way i would imagine you guys up north need them but us in the south dont really....
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 04-12-2009, 10:21 PM   #2
fine69
fine69's Avatar
Re: who still uses a thermostat?
A thermostat regulates how much and fast your coolant runs through your system.
If you don't run one you will more often than not overheat.
I always run one.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-12-2009, 10:21 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you need one regardles of where you are.
The thermostat gets you to a certian temperature, and then keeps you there. Without it, your'll run too cool, and then too hot.
It's a very bad idea to remove one. If they weren't needed, they wouldn't be spending money on them since the dawn of the water cooled engine. GM will do what ever they can to save a nickle... that woulda been axed years ago if not needed.
There are absolutly no pros to removing it for street use.
Old 04-12-2009, 10:26 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
X3
I think it helps with the over all efficiency of your motor. On short trips it will allow it to fully warm up, otherwise you could build up condensation in your motor.
IMO you should use one. If you have cooling issues removing a t-stat is only a band-aid fix.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-12-2009, 10:34 PM   #5
Skirkpat
Skirkpat's Avatar
as stated it is a necessary item, as is a temperature guage. Check and balance...if the thermostat malfunctions, your temp guage will tell you it is time to pull over and turn off the engine.
Skirkpat is offline   Reply With Quote
Old 04-12-2009, 10:35 PM   #6
kgt
Always run a t-stat on a machine that see's street use. Remember that a t-stat controls min operating temp. You need one to slow the coolant flow down to allow the rad time to extract the heat from the coolant as well. There is no reason on a properly set up cooling system to run without a stat.
kgt is offline   Reply With Quote
Old 04-12-2009, 10:35 PM   #7
Dark Knight
Dark Knight's Avatar
Your best bet is to buy a "Fail Safe" thermostat from your local parts store. If it happens to fail, it will fail in the open position, allowing coolant to circulate. Or you can go to Summit Racing and buy one of their high-flow thermostats if you have cooling problems.
Dark Knight is offline   Reply With Quote
Old 04-12-2009, 10:35 PM   #8
ap2002
no cooling issue, just wondering about it since my dad used to do it back in the day...
i know for the new generations the sale an aftermarket thermostat like a 160 and a 180 degree one... are there options like these on the BBC?
Old 04-12-2009, 10:40 PM   #9
Jim_PA
That old gag, eh?
The 160-180 T-stat trick to fool the computer into thinking the engine is cold, so it needs more fuel.
Waste of time
Jim_PA is offline   Reply With Quote
Old 04-12-2009, 10:41 PM   #10
kgt
Alot of stuff was done in the "day" some good, some not so good..lol...big and small block chevys use the same stat...as far as 160-180, i use a 180 in my 468 with dart heads, 714 lift cam and to much compression and it runs down the road at 170-180 and at idle in 100 deg summer heat will run up to 220, and stay there, it has a custom copper 4 core rad and 2 elec. fans.
Old 04-12-2009, 10:59 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Being raised in south Texas (Corpus Christi) where it rarely got below freezing in the winter, I knew a lot of people that ran without them -me included. Never had any problems. Of course this was back in the days before emission control stuff and computer cars.
About the only thing I can think that may have been affected would be the gas mileage. But back in the late 50's and 60's not too many people paid attention to that. Gas was cheap, cars got 8-12 mpg, and if you went 60K-80K on an engine without a major problem you did good.
68gmsee is offline   Reply With Quote
Old 04-12-2009, 11:22 PM   #12
tim21391
tim21391's Avatar
they arnt very expensive to get a new one..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-13-2009, 12:00 AM   #13
69halfton
69halfton's Avatar
not a good idea to run without one on the street. in fact we even run on on our circle track cars up here! although its not functioning, we run a hollowed out one just to slow the water down a little bit. I've found that if it is wide open, and the water pump is turning really fast (the motor never sees the south side of 5000 RPM for a long time ) the water runs through the rad too fast and doesn't even get a chance to cool off.
also being in canada, we need a thermo to keep the engine warm in the pits, otherwise it would never warm up
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 04-13-2009, 12:28 AM   #14
retselgerg
retselgerg's Avatar
get a stant superstat 180..make sure you dont buy a cheapo thermo...it will cost u down the road
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB,
"some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno
retselgerg is offline   Reply With Quote
Old 04-13-2009, 01:05 AM   #15
spinning wheels
spinning wheels's Avatar
I live in So Cal. so warming up an engine in the morning is a rare thing. However, when the weather gets hot, if you are not running a thermostat, and your temp goes up. You will not be able to bring that temp down, with out pulling over and letting it sit for at least two hours. I have seen this happen on my friend's 69 Camaro with a small block. It got hot while driving around a hilly area during the summer, we had to pull over and let it cool down. Chances are, it would not have overheated if we were on the open road, at a steady pace.
If you don't trust thermostats, you can run the flow restrictors like they do in sprint cars.
69halfton, mentioned one method of flow restriction. Check out Speedwaymotors.com website. They sell these flow restictors as well as, some of the good thermostats.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 04-13-2009, 01:09 AM   #16
Camper Power
Camper Power's Avatar
those thermostats are in there for a reason, they didnt just through em in there cause everyone else was.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 04-13-2009, 06:48 AM   #17
Does it rain in these places it never freezes?How does the defroster(think defogger) air get dried @ ambient tempurature.don`t your windows fog up?It doesn`t freeze for a large portion of the year up here and when I`ve removed my t-stat in a pinch it didn`t take long to miss it..Also,I run heat when it`s in the 50/60 range.I don`t know anywhere it doesn`t get that cool.
So,that was passenger comfort.About the engine.They are designed to run in a temperature range.The oil is also.Fuel temp to oil pressure are all effected by operating temp.Fuel efficiemncy will drop w/o a t-stat.a motor run w/o one will have more deposits built up in all fluid passages.
Why re-engineer a vehicle over one of the cheapest parts on it?It takes 10 minutes to switch.carry one in the glovebox if it`s a concern.As far as having a bad overhearing experience,as in detrimental,keep an eye on the gauge.That`s why they call the lights idiot lights.No offense to anyone,but that`s why we want gauges,right?Gauges are intended as a device to monitor problems before they ruin something.There are many other causes of overheating besides stuck shut thermostats.
Old 04-13-2009, 03:05 PM   #18
69GMCLonghorn
69GMCLonghorn's Avatar
Ok, so let me whoop a dead horse. If you're overheating with a thermostat installed, fix the overheating problem. Removing the T-stat is putting a band aid over the real problem, and it will come back to bite you eventually.
Growing up, my dad had a '69 Chevy 3/4 ton with a 307, no O/D. He still claims he got 19 - 20 at 70 MPH when it was new. I didn't know my dad smoked crack...
69GMCLonghorn is offline   Reply With Quote
Old 04-13-2009, 05:34 PM   #19
big_al_71
big_al_71's Avatar
Always have a thermostat in every one of my motors.Everyone has covered the reasons why, no sense in my retyping them.
Trust me fix the overheating problem.
Radiator flush or replace, cooling fan clutch replace if using one, if electric fans make sure that it is big enough, check your fan shroud, fan blades, water pump check everything...good luck
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-13-2009, 05:59 PM   #20
cdowns
cdowns's Avatar
i had a flat tire once but i still use tires on the rims and thermostats in the engine too
Old 04-13-2009, 06:09 PM   #21
ap2002
thanks for all the replys, i was just asking since he seemed to do it back in the day and never had issues? but everything does make sense, and yes, i know about carrying extra parts for sure, before i start driving often, i going to put a new waterpump, starter, thermostat, alternator, fuel pump and carry extra belt, that would make me feel more comfortable riding in it..
Old 04-13-2009, 06:19 PM   #22
GMC AMI
GMC AMI's Avatar
Yeah I rushed this issue ONE time only and was racing a 72 402 BB Chevelle. Before I even got to the staging light the beast overheated due to no Thermo. It needs to slow down the fluid as stated so you do not overheat! It was 90 in the shade that day. It would have served me better to have placed a washer where the thermo goes in order to slow down the fluid.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 04-13-2009, 07:22 PM   #23
68gmsee
Active Member
68gmsee's Avatar
Gotta rattle this can a little more.. Especially for those of you born after 1950...
First I gotta say, I use thermostats in all my cars now but when I was young I lived in the country and auto parts stores were long ways off. If your thermostat went bad, you removed it.
In those days before the mid 1960's or so, A/C, power steering, power brakes, automatics transmissions were not very common. Heck, in south Texas we never used anti-freeze (was it available?). I don't ever remember having any problems running without the thermostat other than it took longer to warm up in cold days.
Someone mentioned "defrost." Without a/c all we ever got was a foggy window. I just opened the vent window and used a cloth to wipe the fog so I could see.
Old 04-15-2009, 11:19 PM   #24
MagmaJct
MagmaJct's Avatar
Why not just grab a textbook on engines? A text book can explain the purposes of a thermostat much better than I could. A good collection of text books, both general and for a specific vehicle, is a good thing for a mechanic to have.
You own an old vehicle? You are a mechanic, and you want to be the best mechanic for your vehicle.
MagmaJct is offline   Reply With Quote
Old 04-16-2009, 03:51 PM   #25
spinning wheels
If I buy the text books, do I have to read them?
Sorry I just couldn't resist that.
I agree, a good repair manual can be very helpful. It sure beats doing repairs under assumptions. But what ap2002 was asking is a valid question, as many old timers removed the thermostats because a friend of a friend had one fail and ruined an engine. We have all heard those stories. These stories probably go back to the Ford flathead days, as the flathead were notorious for overheating.
I think the removal of the themostat goes hand in hand with the roll of toilet paper in the oil filter canister, instead of a store bought oil filter element.
