Old 04-12-2009, 10:54 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
transmission
while driving on the highway it just wont shift into a high gear i have to keep it floored most of the time intill it shifts up higher it use to not do this so whats the problem
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 04-12-2009, 11:53 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: transmission
huh?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 04-12-2009, 11:57 PM   #3
chevymotocross
chevymotocross's Avatar
Re: transmission
What model transmission? Have you checked obvious things first? Fluid level, TV Cable, disconnected/broken vacuum or electrical lines to the tranny?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 04-13-2009, 07:08 AM   #4
pokethesmot
Re: transmission
fluied level is good as as far as i know everything else is too and i have a 350 tranny
Old 04-13-2009, 08:05 AM   #5
85Bowtie
85Bowtie's Avatar
Re: transmission
It sounds like you need to adjust your TV-Cable.
http://www.tciauto.com/Products/Inst...ble_adjust.htm
I believe, even though I haven't messed with it in a very long time, you can adjust transmission shifts through your muodulator on the transmission itself, you have to pull the hose off and you'll see a screw there you can turn one way or another. But, I would mess the cable first since it's likely you've messed with that.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 04-13-2009, 09:26 AM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: transmission
While you had the Pan off of the motor is there a chance that you unplugged the vacuum line for the transmission?Wouldn't have to bump it too hard to do that.
powerdriver 1958 is offline   Reply With Quote
Old 04-13-2009, 09:58 AM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: transmission
I just want to make sure im getting this... the truck wont shift into third gear at like 25 mph? could be either a bad vacuum between the trans and manifold or the modulator could be bad too.. You also need to make sure the fluid is red and not smelling burnt
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-13-2009, 12:03 PM   #8
pokethesmot
Re: transmission
well now im about 90 percent shure its a vacum leak cuz when i push the gas it sounds like a vacuum leak and it was doin it before i changed the rear main seal
Old 04-13-2009, 09:01 PM   #9
pokethesmot
Re: transmission
Bump
Old 04-13-2009, 10:40 PM   #10
powerdriver 1958
Kid's Mechanic
Re: transmission
Poke you haven't said anything about checking the vacuum line to the modulator.there is a steel line that runs from the back right of the tranny to a vacuum port behind the carb with rubber hose on each end.That is the 1st thing to check
Old 04-13-2009, 11:17 PM   #11
78 Chevyrado
Re: transmission
My tranny did the same thing when the hose on the end of the modulator line cracked and came apart.
78 Chevyrado is offline   Reply With Quote
Old 04-14-2009, 12:42 PM   #12
pokethesmot
Re: transmission
well the hose on the modulator looks to be ok but when i press the peddle down i hear a hissing sound like its a vacuum leak and when i press all the way down on the gas i seem to lose speed
Old 04-14-2009, 08:25 PM   #13
powerdriver 1958
Kid's Mechanic
Re: transmission
well now maybe you have a totally different thing going on,that sounds like the exhaust or catalytic converter might be plugged
Old 04-14-2009, 08:51 PM   #14
pokethesmot
Re: transmission
Originally Posted by powerdriver 1958 View Post
well now maybe you have a totally different thing going on,that sounds like the exhaust or catalytic converter plugged
really? it makes a weird sound when i floor it too like a real deep tone that drones on and it dosent even have to be all the way floored to do this
Old 04-14-2009, 09:03 PM   #15
powerdriver 1958
Kid's Mechanic
Re: transmission
look at the exhaust for bent, Collapsed pipe or a spot that has all the rust gone.Maybe even a spot that the pipe looks looks blue.Have had a couple that backed cars in to a bank of dirt and plugged the pipe up
Old 04-14-2009, 09:15 PM   #16
pokethesmot
Re: transmission
well i dint see any bent pipes or anything i have duel turndowns that dump right after the back axle
Old 04-14-2009, 09:28 PM   #17
powerdriver 1958
Kid's Mechanic
Re: transmission
can you get someone to try and help locate the source of the noise
Old 04-14-2009, 09:52 PM   #18
pokethesmot
Re: transmission
well the sucking sound is coming from some wear near the air cleaner
Old 04-15-2009, 04:00 AM   #19
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: transmission
Check the vacuum lines on the intake manifold. It may have come loose and still be hooked up on the trans. Make sure the rubber hoses are in good condition.
You will hear a vacuum from the carburetor especially if the engine is quite.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-15-2009, 08:18 AM   #20
blackdiesel
blackdiesel's Avatar
Re: transmission
Get a can of carb cleaner and spray (with the motor running) in the area where you think the leak is at. The motor will tell you where your leak is.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
