04-12-2009, 10:59 PM | #1 |
Help with brake wheel cylinder
I have a question regarding replacement wheel cylinders for the rear brakes. I have a 72 C10 half ton I am redoing. I just finished putting a new Eaton posi in the rear and was replacing all the brake components as well. I went to replace the wheel cylinders and none of them would fit. I went to O'Riellys, AutoZone, Advanced Auto and CarQuest. Everyone any of them had was different then the originals I took off. They were too wide and would not fit between the ears on the backing plate. The rearend is the original in the truck, I was able to verify that. The factory number on the original cylinders cross-referenced to the new bigger castings. What I did find out is that the rebuild kits for the 6 cylinder trucks which mine was originally matched what I took off. If I wanted a complete new wheel cylinder, they were bigger. Has anyone ran into this problem? I bought the rebuild kits and honed my originals out but would rather buy new. Help!
Thanks, JJ |
04-14-2009, 08:05 AM | #2 |
Happy to be here
Re: Help with brake wheel cylinder
Anyone?
04-14-2009, 09:36 AM | #3 |
Last time I did my 68 in '00, the replacements I picked up @ OReilly's fit. Maybe someone else can offer a more current experience.
