Help with new 327 and original gears
I have put a 300 horse 327 in my 72 longbox c10. it has the original 3 speed tranny and original gears in the rear. will this be good enough for highway use? anyone have experience using this setup?
1972 longbed- 454 1967 shortbed- 355 |
Re: Help with new 327 and original gears
really need help
another question, will it go highway speeds under 3000 rpm? i dont want to waste gas like that
User #12137
![]() Join Date: Apr 2004
the 327 will do fine and the 3 on the tree will be fine as for the rearend it depends on what gear is in there for interstate use or not
![]() Join Date: Jan 2009
my 350/th350 with a 3.08 did almost 3000, if its a manual it would probably do between 2500 and 2700 at 70
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
im not positivly sure what gears are in the rear, but they are the stock ones that came with the custom 10 inline 6 half ton
likely 3.73 gears if it was 6cyl, 3 rower.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
nowthat i think about it they are 3.73
By today`s standards,anything w/o overdrive screams at hiway speeds.Going by what these trucks were built for when new,it`ll be just fine.Will it cruise below 3,000 at 70...nope.Sounds great and I love it.I remember the new vehicles coming out with o/d and thinking what a gutless droan they made.Times have changed,that`s for sure.
#10 | |
6cyl, 3speeds cruise at 60mph with 3.73s fine. what size tires you have?
i am not sure what size tires i have but i have the stock wheels. i would imagine that the wheels would be close to the same. i also have a v8
#13 |
you can run a little taller tire on stock wheel, an allterrain 30X9.50 and run 65mph just fine
#14 | |
v8's came standard with 3.08's I6's came with deeper gears, 3.73's I think
#15 | |
its all about the +6 inches
As far as the gearing, 3 on the column came with a 3.73 regardless if it was a small block or an inline... unless otherwise optioned. |
#16 | |
