Old 04-13-2009, 01:08 PM   #1
Strider
Strider's Avatar
GM Cast Iron Bellhousing Depth
Anyone know how deep a cast iron bellhousing from GM is?\
Aluminum ones are 6 1/4 inches deep.
Chime in if you know!
Cheers!
1967 C-10 250 I6 w/ TH350 3.08 10 bolt HUGGER ORANGE aka "The General"
'57 GMC short step REGINA SPECIAL
2013 CREW CAB SILVERADO 5.3 6 SPEED Z71 WHITE DAILY DRIVER
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth." ~Sherlock Holmes
"Deeds will not be less valliant because they are unpraised." ~ Aragorn
Strider is offline   Reply With Quote
Old 04-13-2009, 01:26 PM   #2
Jim_PA
Re: GM Cast Iron Bellhousing Depth
From what I remember, they are the same.
Jim_PA is offline   Reply With Quote
Old 04-13-2009, 03:23 PM   #3
Strider
Strider's Avatar
Cheers!
It seems that anyone that uses a T5 trans behind a cast iron bellhousing versus using an aluminum one does not have to use a transmission spacer..............or am I incorrect?? I have seen some that use no spacer and some that use a spacer.
I was considering using a bellhousing spacer to move the bellhousing back from the engine which will give me more space to make up for the overall length of the bearing retainer and the input shaft and allow the trans to bolt to the bellhousing.
I believe that Brad on here (the guy with Six Appeal!) did not have to cut his T5 input shaft.
Thoughts??
Thanks!
