04-13-2009, 02:07 PM | #1 |
Dual brake line upgrade
I just upgraded my brakes this weekend. I used the master cyl from a '70 Impala ($24) 60in pre-made brake line ($5) got brass brake adapters ($15 i think) and I'll tell you what! Stops SOOOO much better! If anyone is debating or holding off on doing this cause they're not sure, it is very much worth it! I was very impressed on how much easier and faster I can stop now.
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
04-13-2009, 02:53 PM | #2 |
Why does it taste purple?
Re: Dual brake line upgrade
I just purchased the required fittings about 5 minutes ago. This project will be under way this week
Hello, my name is John and I'm a truckaholic |
04-13-2009, 03:06 PM | #3 |
how a bouit some pics ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
04-13-2009, 03:08 PM | #4 |
I'll post pics tonight when I get home from work, don't have camera with me, sorry.
04-13-2009, 03:20 PM | #5 | |
PIMPING RIDES
what is the route path for dual brake lines ?
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
04-13-2009, 03:24 PM | #6 |
I followed the original single line straight down and along the back of the cross member to the other side where the front and rear line 'T' off each other. Plugged the hole in the 'T' fitting and used a union to mate the new line with the original line that runs to the back.
04-13-2009, 06:38 PM | #7 |
Are you still using drums all around? Will it still work good for discs? I my upgrade someday.
Eugene
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
04-13-2009, 06:45 PM | #8 |
yep, I'm 4 wheel drum. Disc/drum and disc/disc setups will already use a dual line system so there would be no need for it in that case. In fact you do not want to use a drum/drum master cyl on a disc/drum or disc/disc system as it will most likely not create enough pressure to engage the discs. We'd call that 'your gonna die' brakes
04-13-2009, 07:29 PM | #9 |
Oh one more thing , Did you just need one 60" line ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 04-13-2009 at 07:29 PM. |
04-13-2009, 07:38 PM | #10 |
I used on 60" line to tie into the rear line. It was a little long, the next size down in 51" which might be too short to give enough clearance to remove to oil pan in-car. I went with better safe than sorry. I used the original line for the front half.
04-14-2009, 12:04 AM | #11 |
Not the best brake line fitting but it it was my first try
04-14-2009, 12:34 AM | #12 |
very cool thanks
04-26-2009, 05:05 PM | #13 |
I just got finished with my swap and I bled the living hell out of the system and have a low brake pedal. There is no air in the system at all. No leaks, nothing. What gives?
Also had to replace the passenger side brake hose. I'd like to know how long that bad boy had leaked lol
04-26-2009, 05:58 PM | #14 | |
04-26-2009, 07:54 PM | #15 | |
04-26-2009, 09:27 PM | #16 |
If you replaced the master cylinder also, that has to be bled first, usually in a vise. Then mount ,add new lines,a little coil in the brake lines will help relieve chassis movement, then bleed farthest line first.
04-26-2009, 09:53 PM | #17 |
for sure a great upgrade....for drum drum. cheif rocka has a write up as well.
04-26-2009, 10:31 PM | #18 |
Hollister, CA.
How about we split your lines and swap the axle at the same time.....you ready yet ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
04-27-2009, 11:26 AM | #19 |
I am ready, but my wallet is not!!! Hope fully soon. Hey bro how is your dad ?
04-28-2009, 07:50 PM | #20 |
I finished bleeding air out of my lines today. What a pain. I thought I had it all out........I guess not lol. Adjusted all brakes and nice improvement. It probably never stopped this good when it was new. I love it and recommend everyone to do this upgrade if they haven't already
