Old 12-24-2002, 12:39 AM   #1
low 84
low 84's Avatar
brandon, carb specs?
brandon, what sizes of jets and springs and everything are you running in your carb. i have the 1400 but its pretty much the same as the 1406 but with erg and bowl vent ports which i have blocked off. i bought a calibration kit and wanting to use your specs as a base line. i think we'll be putting out about the same power so it should get me close enough to fine tune it.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
