Rear Air Bag install ?'s
I need to know and see a pic if posible of the rear 7" bag installed
without a c notch.... Just wondering if it will give the lowered look with out the c notch. I'm not looking to lay on the ground. last minute worry bug is hittn. Got a plasma coming tomorrow so I need to know....? Cheers ![]() ![]() ![]() ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
![]() Join Date: Sep 2008
Re: Rear Air Bag install ?'s
![]() D2600's inplace of the stock springs. frame rails sitting on the axle tubes. dont have a pic with the bed. bottom the the bumper is 19'' full - 10'' dumped, that would change with tires sizes. |
You ask this same question in another thread and now have started a brand new one asking the same identical question.
That's called double or cross-posting and it's a no-no. Ask a question in one place then be patient for an answer. Thanks. Last edited by Shane; 04-13-2009 at 06:01 PM. |
Search for my previous posts as I attached photos of my truck after the drop. Bags front and back with no C-notch. I did remove the stock rubber bump stops in the back so as to all a little more travel when lowered.
I would send you a pic, but I'm currently deployed and don't have pics on me.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
Awsome......
#6 | |
He's doing a service that this site requests of him.
... it's spelled STALKER
![]() Last edited by N2TRUX; 04-14-2009 at 11:04 AM. |
Happy to be here
![]() Join Date: Mar 2000
Shane's point is you will get better results if you keep your topic in one post. People tend to ignore multiple postings asking the same or similiar questions.
If your not getting the results you want, try asking the question in a different manner in "the same" thread.... ![]()
Nicks05z71
do you have any pics of the top side of that bag mounted tot he frame? i am about to install the same bags on my '69 and i am curious how you oriented the two bolt holes. 67chevemall, i understand your need wish i could help. i have a hard time getting a response with any of my posts. i think your supposed to post "ttt" on your thread if you are trying to keep it from getting buried and make it more visible. someone correct me if i'm wrong but i think ttt means to the top. |
OK boyzz. Will do.
I think I have er now. Tonight is go time. I'll take some pics. Going to make a new thread when I have all my pics so nobody will have to stress about bags. Cheers to this site. |
#13 | |
I very carfully made templet of the top of my bag, and marked out the centers of the mounting holes and the airline hole. Then I marked the center of my templet ( center of bag ). Now take the center of the templet and aline with the old spring mounting hole, mark centers of the holes needed to drill..... only thing.... make your templet, then tripple check the centers of the holes! You might even want to try this templet on cardboad first. I found that out the hard way! When your done it will look somthing like this. ![]() My airbag holes were more center with the hole in the middle. This is just a picture I found on the site. Last edited by nicks05z71; 04-15-2009 at 01:52 PM. |
#14 |
Ok thanks. thats what i needed to see.
