Old 04-13-2009, 05:37 PM   #1
BigAl
Fuel Relay Fuse Location
Hi!
I've got an 87 Silverado with TBI and dual tanks.
Symptoms:
-crank but no fire
-will catch with starting fluid in the TB
Problem:
-No Voltage is showing at the Fuel Pump relay
I diagnosed this by removing the relay from the harness and using a test ligt on all 5 connections. My Haynes manual says that the Orange Wire is supposed to be hot at all times...
Haynes also says that there is an inline fuse between the junction box and the relay that is 20A.
Where is it? <---- I think this fuse is the problem...
Why? - I replaceed my radiator and when finishing up - accidently hooked up the battery backwards. Fried the alternator...Like I said before - everything seems to be working except for fuel into the engine...
Thanks for your help!
Al
BigAl is offline   Reply With Quote
Old 04-13-2009, 07:52 PM   #2
73chevyman
73chevyman's Avatar
Re: Fuel Relay Fuse Location
hmmmmmmmm did you check all the fuses in the block. now my fuse in my 94 Z24 was in the fuse block thats where it should be. replace all fuses and your relay. see what that does. I never done that before
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-13-2009, 08:13 PM   #3
BigAl
You're right - now functioning after replacing a burnt 10A fuse at "ECMb"
-Thanks!
More problems though....I believe the fuel tank selector moter just kicked the can in the wrong position
Old 04-14-2009, 07:58 PM   #4
73chevyman
73chevyman's Avatar
glad i could help hope you get all your problems solved so you can drive the piss out of it after keeping you stranded lol good luck man
73 C10 Fleetside
