Old 04-13-2009, 07:44 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Question Engine builder says to use valvoline 20w50
I searched and nothing came up.
I’m not sure what weight to use, but I called three different machine shops and 2 said use Valvoline 20w50 and one said another said Castrol 20w50. They all said to use the comp cams oil additive with zddp.
Is that too thin of oil? I give up. I’ve got 5 quarts of NAPA 20w50 (Valvoline) ready to go in with the comp cams oil additive.
What are you running?
You call any performance shops they want to sell you Joe Gibbs oil $$$.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-13-2009, 08:03 PM   #2
Painter D
Painter D's Avatar
Re: Engine builder says to use valvoline 20w50
They're recommending the VR-1 20w-50 because it still has plenty of zddp in it already, without the additional additive. I flattened a (new) cam a while back from not using the propper oil. Just use the Valvoline VR-1 and you should be fine. I use it in my truck.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 04-13-2009, 08:05 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
Ill second that, VR-1 is some good stuff. What I run in my race motor. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 04-13-2009, 08:27 PM   #4
Sport/Truck
Sierra Grande Club
What do you run in your 69 c-10 Daily driver?
s/t
Old 04-13-2009, 08:32 PM   #5
Sport/Truck
Sierra Grande Club
They didn't specify the VR-1 they said "any good oil, like Valvoline".
The VR-1 I'm sure is a fine oil though.
s/t
Old 04-13-2009, 08:48 PM   #6
67shortie
Green club
67shortie's Avatar
If you can't find VR-1 try the DELO 400 oil, it has a good amount of ZZDP in it, and of course along with the Crane super lube or the tried and true EOS from GM, I bought mine at the local dealer for $18
never lost a cam with this combo.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 04-13-2009, 08:49 PM   #7
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
You can use any oil you want - BUT - use an additive - GM EOS (1/2 bottle per oil change - full bottle for breakin)
Comp, Jegs, Summit all make additives as well
I use Lubriplate GPO motor oil myself - they still have plenty zinc - cheaper than Joe Gibbs - and they pay the freight to my door when I buy it by case
Please also use a NAPA gold filter - NAPA, wix make the best filters
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 04-13-2009, 08:49 PM   #8
Jokers69
Active Member
Jokers69's Avatar
The best oil for camshaft's is Brad Penn oil. It has high zinc levels and can be ran with any mechanical, roller, or hydraulic cams.
Jokers69 is offline   Reply With Quote
Old 04-13-2009, 08:50 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Just curious... Why 20W50? Recent rebuild? Racing engine?
68gmsee is offline   Reply With Quote
Old 04-13-2009, 09:42 PM   #10
mvfd70
mvfd70's Avatar
What about Royal Purple? They've got a break in oil that says it's for flat lifter cams.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 04-13-2009, 09:55 PM   #11
Jim_PA
Huh... I use straight 10W-30. Mobil 1 actually. Maybe time to change.
Jim_PA is offline   Reply With Quote
Old 04-13-2009, 10:03 PM   #12
Southpa
Southpa's Avatar
I used to use 10W30. Then on a really HOT summer day a mechanic told me I should be using heavier oil. I live in a moderate climate, Vancouver Is., where temps rarely go below freezing for any length of time. I think by using 20W50 exclusively since 1995 I have prolonged the life of my engine. Old engines run smoother with heavier viscosities between all those worn moving parts.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-13-2009, 10:03 PM   #13
Sport/Truck
Sierra Grande Club
I like the Delo Idea. From what Ive read racing oil's aren't recommended
for street cars because the lack of detergent.
I use NAPA gold all the time .
Didn't they change the formulation of the GM EOS though? That's why I was looking elsewhere for the ZDDP.
I'll look into the Lubrplate oil.
Thanks.
Brand Penn- I'll also look into this as well.
That what 3 out of 3 engine builders suggested.
Not sure myself, something doesn't seem right? Didn't our trucks originally run straight 30w or 10w30?
s/t
Old 04-13-2009, 10:15 PM   #14
1968SWBBigBlock
Active Member
The formulation of EOS did not change - they had to change the part number and description so it would not be used with catalytic converter cars.
I found a bunch (10 bottles) under the old part number at the local pontiac dealer - they where thrilled to sell me all 10 bottles for 4.99 per bottle to get the old part number out of inventory
1968 SWB
Old 04-13-2009, 10:19 PM   #15
Sport/Truck
Sierra Grande Club
I've heard good things about all synthetics, I haven't seen the break in oil.
I don't know. I've used 15w50 in my import for 15 years. That motor was soooo clean inside you wouldn't believe it had 190K on it. Granted it was all roller too, so no cam issue.
That's what is confusing to me. The cold difference isn't that much between a 10w = -20* and 20w=0* They both (30 & 50) are rated over 100*
s/t
Old 04-13-2009, 10:21 PM   #16
Sport/Truck
Sierra Grande Club
Do you use the whole bottle at each oil change?
s/t
Old 04-13-2009, 10:23 PM   #17
1968SWBBigBlock
Active Member
Use a whole bottle during breakin - after that use 1/2 a bottle per oil change
1968 SWB
Old 04-13-2009, 10:24 PM   #18
1968SWBBigBlock
Active Member
FYI - a couple of folks posted synthetic oils - breaking in with synthetic oil is normally a no no ---- they are to slick and will not allow your lifters to spin in the bores and on your cam lobe - this will cause premature wear and wipe your cam
1968 SWB
Old 04-13-2009, 10:33 PM   #19
Sport/Truck
Sierra Grande Club
Now a little more clarification on the 1/2 bottle treatment. Would that be with an oil that has basically no ZDDP or with an oil like Delo with some in it? ( I think you meant with the basic oil).
I've heard that too, but think maybe the ones mentioned make a non Synthetic break in oil?
s/t
Old 04-13-2009, 10:56 PM   #20
chipflyer
chipflyer's Avatar
This is the ZDDP additive that I use with every oil change.
http://www.zddplus.com/
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 04-13-2009, 11:01 PM   #21
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I have gotten to where I use 20w 50 in anything but my two new drivers, this includes my trucks and tractors. I use the manufacturers recommended weight royal purple in my two drivers (08 mustang and 08 charger).
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-13-2009, 11:02 PM   #22
Sport/Truck
Sierra Grande Club
I've read some good stuff about that. Do you order yours over the .net? seems fair priced too.
s/t
Old 04-13-2009, 11:19 PM   #23
chevybuldr
chevybuldr's Avatar
Don't go the Delo route that is for Diesel only. The ZZDP is rated at differnt levels. They are actually starting to take that out of Delo also. Actually went to an intersting seminar from Gibbs oil. Because of the heat of a diesel it reacts much different then say you street car. Any oil that says that its for off road use only has the additive in it. Why not just buy your regular oil and add the comp additive. Dont run a synthetic till the motor is broken in, maybe 2000 miles. Got to get everything to seat and the thing that needs to seat the most is rings.
chevybuldr is offline   Reply With Quote
Old 04-13-2009, 11:22 PM   #24
monte0185
monte0185's Avatar
Ive done just what my engine builder taught me 15 years ago and never had a problem. About 5 years ago he added the part about the break in oil.
Build the engine with 70 wt oil on all the bearing surfaces and the best cam lube you can find on the lobes. I use some stuff that he gets from a custom grinder he uses. I cant remember the name. Been awhile since I put a bottom end together. The one im doing currently he built the bottom end for. Anyway I use straight 30 weight oil and a bottle of break in oil for 5 hours. Change the oil to 10/30 valvoline and another bottle of break in oil till the first oil change. After that I switch to castrol syntec and i have never had a lobe flatten.
Now there are lots of recipies for break-in and every engine builder will give you a different one almost guaranteed. Most older ones like valvoline cause its one of the top proven brands thats been around as long as oil has been. Usually the best thing to do is pick the one that works for you and stick with it.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-13-2009, 11:23 PM   #25
Texasbigblock
Texasbigblock's Avatar
80% VR1 20-50 with 20% lucas oil additive
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
