Always wrenching!!
Reverse light help.....
My lights don't work. bulbs are good, fuses are good. Do the lights get activated by a switch in/on the column or from the tranny? any one have a good wiring diagram off the reverse light circuit?? thanks in advance.
and FYI.......... the truck now has a 4l60e trans..... but the lights didn't work before the engine/trans swap.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress Last edited by Sicmaro; 04-13-2009 at 07:46 PM. |
Chemist under the hood...
Re: Reverse light help.....
On the three speed column shift, the switch is near the bottom of the column under the dash. On my truck, the guy converted to floor shift and installed a toggle switch to turn on the reverse lights!!!
Always wrenching!!
the toggle switch crossed my mind, but if the switch is on the column then i should be able to fix it up.
Any one have any pics of the switch and a wire diagram??
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
Here's a diagram from my 1967 Shop Manual. Hope that helps.
on my eclipse they didnt work so i put new switch on tranny and they worked... maybe its that
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
![]() Join Date: Jun 2007
You neutral safety switch needs replaced. 2 screws and its out, it's at the very bottom of your column. Try and start it in gear and if it does the switch is out. If it doesn't then check your connections on the switch.
![]() Join Date: Nov 2007
I just recently got mine working. After making sure the grounds were good the lights still didnt work. Bulbs, fuse, lights, and ground were good. Turns out the prongs that hold the fuse in, were dirty and not getting a good connection. Might be something to look into to
