04-13-2009, 08:13 PM | #1 |
Between Trucks...
Parking Brake Issues
Replaced the main parking brake cable, seemed a little too long. Lot's of slack even adjusted all the way tight. Do the cables coming out of the backing plates stretch a lot? Parking brake won't hold the truck on a hill.
Beat it to fit, Paint it to match... |
04-13-2009, 09:01 PM | #2 |
Active Member
Re: Parking Brake Issues
All of the above... Make sure your rear brakes have good tread and adjusted so that they barely touch the rim when rotated.
Spray lubricant on the cable sheathing might help. On one of my trucks I had to add some shims (larger sized nuts) on the backside of the adjusting bolt so that they would tighten enough. |
04-13-2009, 09:10 PM | #3 |
Between Trucks...
Thanks for the quick reply. I was thinking about some shims. There is also a bracket/guide on the passenger side that I was thinking of making shorter, but I don't want to mess it up if I have to replace the backing plate cables and things get too short.
04-13-2009, 09:20 PM | #4 |
J'ville Junkman
I don't want to insult you or anything. But, you do have the cable looped through the thingys that hook to the frame? I memory serves these are on the frame sorta under the door.
The reason I ask is this same thing happened to a "friend" of mine, yeah a friend.
72 3/4t Suburban 402BB (Daily driver for 8 years) 68 GTO (never ending proj) 91 Kawasaki ZX-7R 57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans) 73 Corvette (17 yr old daughter's: Another project - what's wrong with me?) 53 Willys M38 |
04-13-2009, 09:21 PM | #5 | |
The Older Generation
LockDoc
04-13-2009, 09:24 PM | #6 |
Between Trucks...
The cable is running through both guides. I was under the impression the rear brakes self adjusted, might have to pull things apart and see what's up. This on a '69 C-20 if it matters.
04-14-2009, 09:22 PM | #7 | |
Active Member
I always pre-adjust the brakes and then every once in a while, when I can remember and their ain't no one behind, I'll go in reverse and stomp the brakes. |
