Old 04-14-2009, 12:17 PM   #1
mkmc69
mkmc69's Avatar
350 4 bolt main 1 piece rear main seal
I am looking for a 350 4 bolt main 1 piece rear main seal block in the local junk yards. I need to know what to look for to tell me that it is the block that I am searching for. Any info would be helpful. Thanks
mkmc69 is offline   Reply With Quote
Old 04-14-2009, 12:31 PM   #2
monte0185
monte0185's Avatar
Re: 350 4 bolt main 1 piece rear main seal
Go to mortec.com they have all the casting #'s for them. Most are gonna require a visual inspection though cause they can go either way.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-14-2009, 12:32 PM   #3
haysonj
haysonj's Avatar
I believe they are 86 and later on the one piece seals and look for one ton trucks they are usually 4 bolt mains. I don't think you can tell without pulling the pan
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 04-14-2009, 01:46 PM   #4
MonteSS454
MonteSS454's Avatar
87 and later are the TBI "K" motors that came with the 1 piece rear main. Get the casting numbers and head over to Mortec to verify it's a 350 and a for bolt, some will say 2 or 4 bolt so you'd have to pull the pan.
MonteSS454 is offline   Reply With Quote
Old 04-14-2009, 02:44 PM   #5
soba_03
soba_03's Avatar
I have a 350 .030 block it's a 2 bolt and one piece rear main seal. Freshly punched, got a set of cam bearings and freeze plugs for it. siting in the corner of the garage. If your not stuck on a 4 bolt. I'd probally let it go for a fair price..
soba_03 is offline   Reply With Quote
Old 04-15-2009, 09:46 AM   #6
mkmc69
mkmc69's Avatar
I was afraid of that on pulling the pan to verify, thanks for all of the help guys. Soba I will keep you in mind if I can't find what I am looking for.
Old 04-15-2009, 10:12 AM   #7
chevybuldr
chevybuldr's Avatar
There is no way to tell a 4 bolt from the outside. Serious you are not really going to notice a difference in a 4 bolt or 2 bolt. Sure its nice and if you can get one then grab it. One thing about about a late motor is though make sure its not cracked in the valley(lifter area). They are notorious for cracking there, mainly accross the head bolt boss. Makes good sense to see if they offer a warrenty. Also check craigslist somtimes you can find one that is sitting in a guys garage.
chevybuldr is offline   Reply With Quote
