04-14-2009, 06:05 PM | #1 |
1970 C10
Stripped bolt help!
I'm in the process of cleaning up the motor, and found that the long bolt that holds the alternator in has a stripped head....
whats the best way of getting it out?? i thought about just drilling a small slit and trying to use a large flat head screwdriver to get it out. whats the best option for me? |
04-14-2009, 06:16 PM | #2 |
Between Trucks...
Re: Stripped bolt help!
Vice grips, or you could weld a nut to the bolt.
Beat it to fit, Paint it to match... |
04-14-2009, 06:17 PM | #3 |
check these out...I got a set at my local sears and they have bailed me out many times http://www.sears.com/shc/s/p_10153_1...2060000P?mv=rr
04-14-2009, 06:19 PM | #4 | |
1970 C10
i may run up to sears to grab a set |
04-14-2009, 06:24 PM | #5 |
sharp as a marble
cut the head off with a hack saw or a cutoff wheel. slide the alternator out of the way , and put a set of vise grips on the bolt. IF the bolt is not bottomed in the head you should be able to unscrew the bolt.
04-14-2009, 06:35 PM | #6 | |
Gone to greener pastures
Then try to back the bolt out again.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-14-2009, 07:30 PM | #7 |
i have a set of snap on ones you jsut trap on the right size one and take a wrench and turn it out like normal
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-14-2009, 07:49 PM | #8 |
i usually grind two flat spots on either side of a damaged bolt head, then just use either a crescent wrench or a vice grip ad winch it off.
04-14-2009, 08:04 PM | #9 |
1970 C10
It expanded nicely and was stuck around the alternator itself, i just ended up using a cut off wheel and cutting it right past the alternator.
Thanks for the help! |
