Old 04-14-2009, 07:10 PM   #1
57larry
Gas tank for a 56
I want to install a rear under the bed gas tank on my 56 step side 1/2 ton. I see where Brothers sells one, anybody else sell them? I'm going to put the fill on the passenger side fender. I see a tech article on a 67-72 truck, any for a 56? thanks
57larry is offline   Reply With Quote
Old 04-14-2009, 10:35 PM   #2
low57
low57's Avatar
Re: Gas tank for a 56
Rock Valley sells nice stainless fuel tanks . I am very happy with the tank that I have from them.
low57 is offline   Reply With Quote
Old 04-14-2009, 11:38 PM   #3
OrrieG
OrrieG's Avatar
I got mine from Performance Online, good price and well built. I got side fill, which requires modifications to the bed cross sill, not very well documented or explained. Top fill is ok. Look in my build thread for the install pics and a shot of the modified cross sill.
OrrieG is offline   Reply With Quote
Old 04-15-2009, 07:19 AM   #4
GRIMSS
GRIMSS's Avatar
How low does the tank sit below the frame rails?
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-15-2009, 12:45 PM   #5
OrrieG
OrrieG's Avatar
Here are three shots. One is from the back, notice that the bottom of the tank is even with the center of the stock spring pack. The second kind of shows the side, I don't have a straight side shot. Third shows the bracket modification I had to make, it is going to be reinforced with an angle. If you need an exact measurement I can get it for you.
Old 04-15-2009, 04:43 PM   #6
GRIMSS
GRIMSS's Avatar
It's no big deal but if you get a chance some time it would help me out.
2001 GMC SIERRA
1968 Camaro
Jared
Old 04-15-2009, 05:29 PM   #7
hotrodsbyray
69 cougar will fit but exits out the back. I did see one where the fill tube was cut and another curved tube (I think it was exhaust tubing) was used to run it out the side.
hotrodsbyray is offline   Reply With Quote
Old 04-15-2009, 05:48 PM   #8
Dusty4
In an older issue of Truck Builder, a guy used a repop tank for a 57 Chevy sedan, filler out the fender. These tanks are inexpensive.
Dusty4 is offline   Reply With Quote
Old 04-15-2009, 07:10 PM   #9
renegade6
I've done some measuring and it looks like a late 80-90s Chevy van tank will also work with a side exit.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 04-15-2009, 09:11 PM   #10
57larry
thanks for all the tips guys!
Old 04-15-2009, 11:53 PM   #11
OrrieG
OrrieG's Avatar
First go around I had an second tank mounted in the back out of a 68 Impala with a rear spount. Not pretty but worked. Only draw back was when full and climbing steep trails it would leak around the vented cap. It also hung lower and got pretty beat up over the ten years I had it in there. This aluminum one seem stouter and will be protected by a receiver hitch and secondary skid plate.
Old 04-17-2009, 05:28 PM   #12
Tomb23
70 mustang tank Like a bug 'n a rug
Tomb23 is offline   Reply With Quote
Old 04-17-2009, 05:58 PM   #13
57larry
that's a great fit!!
Old 04-17-2009, 09:05 PM   #14
JML55
JML55's Avatar
Mine was from CPP drv side fill.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 04-18-2009, 08:28 AM   #15
renegade6
Where did you get the gas tank filler door?
Brandon
Old 04-18-2009, 09:29 AM   #16
JML55
JML55's Avatar
From Dodge Dakota early 90's.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
