Old 04-14-2009, 07:11 PM   #1
turner15
When to paint the.box
So I am almost done the box on my 71. Should I assemble it before I paint it? I think it would be better that way it won't get scratched during assembly
turner15 is offline   Reply With Quote
Old 04-14-2009, 07:28 PM   #2
Re: When to paint the.box
I`d panel paint it and be careful.You can always hit it again once it`s assembled if you muff it up.You can assemble it loosely with paper between the panels and pull it out when it`s time to tighten up.
Old 04-14-2009, 07:51 PM   #3
big_al_71
big_al_71's Avatar
when I had my old GMC painted the box was painted off the frame and also that way the rear of the cab wass painted as well. just have to be very carefull when re-asssembling.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-14-2009, 10:53 PM   #4
knsmodels
I make Models
knsmodels's Avatar
when I did mine I blew in all of the panels before assembling....after that I assembled the bed and painted the inside of the bed....then taped off the inside and painted the outside.....after all was dry I put the bed back on the frame.....painted tailgate seperate.....worked out well for me with no damage during assembly......just had 4 guys put the assembled bed in place on the frame when all complete....good luck with it......
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 04-15-2009, 12:57 AM   #5
OARNGESI
OARNGESI's Avatar
Originally Posted by big_al_71 View Post
when i had my old gmc painted the box was painted off the frame and also that way the rear of the cab wass painted as well. Just have to be very carefull when re-asssembling.
is your truck a gmc with a chevy clip
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-15-2009, 01:45 AM   #6
tim21391
tim21391's Avatar
im going to prime everything then stick everything back on the truck but doors... then paint the jams and interior side of doors then stick then back on then paint the exterior
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-15-2009, 06:14 AM   #7
If you put it together primed,then paint,you will have no paint to protect the most vulnerable areas to hold moisture/rust.I`d expect to see rust bleed coming from seams.Seam sealer will stop that,but also trap moisture in there.I would suggest doing as knsmodels did for best results.
Old 04-17-2009, 01:06 AM   #8
72lb4x4
I have no experience, but have been trolling various forums for a long time so disregard as desired. From that "experience" I'd guess the process is ideally as follows:
Rough body work (welding, dents, etc.)
Disassemble if not done
Blast
Seal w/ good 2k sealer
Rage filler
Primer
Block sand, Block, Block
Color on "jambs" or areas covered when assembled
Finish bottom as desired or not
Assemble
Color on all or only front bulkhead and maybe bottom
Mount on frame
Color
Clear as desired
This is assuming the bed goes on after the cab, and obviously some basic steps have been left out and/or forgotten by the halfwit poster (meaning me before anyone swings).
Maybe somewhere in there should be a line about wax or otherwise sealing the inside of the bed walls and bed sides.
Feel free to disagree and suggest a different order since I'm just fantasizing/nightmaring about the process, but I am thinking about it...
72lb4x4 is offline   Reply With Quote
