Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-14-2009, 07:31 PM   #1
mark's68
5 speed to auto swap
I've got a 93 s 10 with 2.8 and a 5 speed. What parts will i need to swap in an auto . Thanks for any help.
mark's68 is offline   Reply With Quote
Old 04-14-2009, 10:58 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 5 speed to auto swap
What type of auto? 350th or 700R4?
I can't remember which engine has the same bolt pattern as a small block. I think the 2.8 is a car bolt pattern. Are you keeping the fuel injection?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-15-2009, 01:13 PM   #3
mark's68
I'd like to go with the 700r4. The 2.8 has the small bellhousing bolt pattern.
Old 04-15-2009, 01:15 PM   #4
mark's68
yes I'll be keeping the fuel injection.
Old 04-15-2009, 05:18 PM   #5
BarryB
BarryB's Avatar
find one from a 93 down camaro, firebird with the 3.1 or 3.4. Same as a 2.8 will bolt right up. You should be able to use the flywheel also. But I am not sure about the balancing of those motors. 93 is before if went electronic so it should be a relatively easy swap.
So why are you wanting to swap, ease of driving??
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 04-15-2009, 10:23 PM   #6
mark's68
yes, tired of shifting. will there be any computer changes?
Old 04-16-2009, 02:49 PM   #7
BarryB
BarryB's Avatar
Know there shouldn't be any computer changes. If at all possible, try and stay with the same year, so you can hook up your speedometer,because it's electronic. should be able to unplug yours and plug into the auto trans sensor. Only other thing is getting the linkage and brakets for the detent cable. A might have to try and find those parts at a pick and pull yard. Heck you might be able to go just get one out a 93 2.8 form the junkyard. that way it will be a pretty easy swap. getting all the brackets for the same vehicle.
Two rules in life.
