04-14-2009, 09:32 PM | #1 |
Rod knock on an engine with 4000 miles??????
my motor was rebuilt 4000 miles ago and today it started making death noises,
at Idle and anything below 2500 it runs perfectly normal above 2500 it sounds like a really bad diesel motor and won't rev past about 3000(the noise gets worse the harder you press the gas) rod knock??? what else could it be????
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
04-14-2009, 09:47 PM | #2 |
Re: Rod knock on an engine with 4000 miles??????
another thing to mention is that it only knocks in gear. tried to get it to do it in drive with my foot on the brake but I couldn't get it to rev to 2500 without it taking off. The 700r4 is new, less than a month old. I guess it could be the transmission but it sounds like its further up.
04-14-2009, 09:49 PM | #3 | |
1972 longbed- 454 1967 shortbed- 355 |
04-14-2009, 09:51 PM | #4 |
maybe check the torque converter bolts. they can make a pretty bad knocking sound when loose
04-14-2009, 10:27 PM | #5 |
Also check your flywheel (flex plate) mine was cracked, thought i had a rod knocking
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold |
04-14-2009, 11:01 PM | #6 |
Ive had a cracked flywheel before, this knock isn't a gentle tapping.
It sounds like someone is banging on my engine with a hammer
04-14-2009, 11:11 PM | #7 |
Sound travels thru an engine, so it can be hard to pin point what is causing the sound. Use a set of stethoscopes, (you can get them at Harbor Freight real cheap). This can help you pin point the noise better. Just throwing this out there, I have heard of water pumps making the thumping sound. The only time I had an engine make that sound, it was a rod knock
'72 GMC custom camper 350/350 |
04-14-2009, 11:33 PM | #8 |
I was thinking flexplate also. If you want to check to pinpoint the noise like spinning wheels said you don't need a scope. Just get a long screwdriver. Good luck though. Did you have a shop do it? Is there any kind of warranty with it?
04-14-2009, 11:52 PM | #9 |
did you have your foot in it a lot before it started making these god awfull noises?
1965 c/10 swb 1969 c/10 lwb |
04-15-2009, 12:44 AM | #10 |
Msgt USAF Ret
Rod knocks are usually heard when the engine is under load like when accelerating or climbing a grade. It shouldn't take anywhere near 2500 in gear to hear a rod knock. I would try taking it out on the road and pulling one spark plug at a time and see if the knock goes away. This relieves the combustion pressure on the cylinder and if the knock goes away then you've found the bad cylinder.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-15-2009, 06:27 AM | #11 |
I`d still look into the flex-plate/torque convertor area,first.It doesn`t always make the same noise and definately can sound like more than a tap.More times than not it sounds like the bottom end is coming out of it.Drain oil into an absolutely clean container and do an oil analysis.Take a piece of something clean,rigid,and white(like corrugated sign board from Walmart),pour oil a splash of oil on there and let it flow down.look for metal bits.If you can`t see anything,run a rare earth magnet over it or even scrape it across with the tail end dragging.If there are no fragments there is no internal damage.I`d also tear the filter apart and see what`s in there.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-15-2009 at 06:28 AM. |
04-15-2009, 07:20 AM | #12 |
an old harmonic balanced on a worn crank snout can sound and feel like rod knock too //just look at it and see if its wobbeling
04-15-2009, 09:34 AM | #13 |
Is your oil-pressure normal? You also said it only knocks in gear, does that mean it does not knock in Park or Neutral?
04-15-2009, 09:42 AM | #14 |
yes
04-15-2009, 09:59 AM | #15 |
it sounds like you know what it is..... if you have a warranty see what they will do. if not....... when i was younger my dad told me that when it comes to driving my foot would be the bigest money saver in my life... didn't understand until i bought tires, brakes, drive shafts, rear ends, motors and was constantly workin on my truck then it just hit me and now i spend my money on things i want instead of what i have broken. lil off topic but just my two cents.... hope it works out
04-15-2009, 09:32 PM | #16 |
well, I must have been having a bad day yesterday. Today the truck is almost normal. Its still making a little noise but its not near as severe as it was yesterday. I'm gonna give the truck a tune-up and see if that helps.
04-16-2009, 04:31 PM | #17 |
It did it again today, I finally checked my oil pressure gauge. when its acting fine I have about 30psi at Idle and about 70psi max.
when it starts making noise it drops to 0psi at Idle and around 20psi max.
04-16-2009, 05:20 PM | #18 |
Low on oil?? And except the oil pressure, I was thinking a ping (detonation) vs knock but a ping wouldn't lower the oil pressure.
04-16-2009, 05:31 PM | #19 | |
Question no. 2: What kind of valve covers are you using? Do they have baffles around the PVC valves? If not, you may be sucking up the oil on the heads thru the PVC valves. This would cause your loud valve train. Question no. 3: In reference to question no. 2. Are you using a lot of oil?
04-16-2009, 06:00 PM | #20 | |
stock centerbolt valve covers. PCV hooked up not using hardly any oil, I have oil in the motor right now
04-16-2009, 07:05 PM | #21 |
Not sure how good equs gauges are. I have seen them around, but I personally don't know anybody using them.
These are just some suggestions, I'm not an expert on this stuff. I only play an expert on the web Low oil pressure, usually means a higher than normal bearing clearance, which can cause a low pressure reading. Or, your oil is not getting to the top of the engine, which would mean your oil pump is either weak or plugged up. Being a new engine, it could have anything from silicone (sp*), to gasket material, or something let loose (failed), on the new engine that has settled into the oil pan and gets sucked into the oil pumps intake. I could be wrong, but I would check your oil pump. Could be something as simple as the shaft damaged. If that is ok, I might pull the oil pan, I know, its a PIA. This would let you get a good view of the oil pump. Have you cut open one of your oil filters, to check for metal deposits? If you don't have a filter cutter, check with the engine builder. Whatever you do, just stay cool, calm, and collected. Keep the young one(s) away, so they won't hear you cusing. Keep the dog(s) away so you won't kick it. Keep the wife or GF away, so well, you know
04-16-2009, 07:19 PM | #22 |
When did you change the oil?How many times?How long has it been?Have you smelled the oil?I wonder if you have drain back from the carb.Or,a wiped bearing?Once the oil warms up oil pressure is low.The crank could be turned a bit beyond tolerance.Was it ground?Undersized bearings?The oil test I described would help narrow down if it`s improper tolerances.There wouldn`t be any grindings.
04-16-2009, 09:01 PM | #23 |
blood type; Retumbo
I'm thinking a spun main bearing or two.
the pan needs to come off, NOW |
04-16-2009, 09:10 PM | #24 |
should i pull the pan???????? or just bite the bullet and pull the motor????????????????????
04-16-2009, 09:16 PM | #25 | |
4 quarts valvoline racing 20w50 1 quart marvel mystery oil I noticed this after the noise started so I guess its connected. usually my oil pressure runs between 40 and 60psi
