Old 04-14-2009, 10:56 PM   #1
ashx2
Question Driprails............
What exactly do you do to the driprail when restoring? Do you caulk it or what? I am getting ready to start removing the rusted areas around the sides of the cab on the driprails, but I am unsure of the steps I need to be taking......I guess you could say I'm running blind.
Thanks,
Greg
ashx2 is offline   Reply With Quote
Old 04-15-2009, 01:19 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Driprails............
do a search on Joint and Seam Sealers, you'll find what you need
dwcsr is offline   Reply With Quote
Old 04-15-2009, 01:28 AM   #3
d10s69c10
Built 4 Speed
d10s69c10's Avatar
grind them off and weld it back up. thats just me.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 04-15-2009, 08:27 AM   #4
ashx2
That's not an option. At least not in my book. That driprail is part of the character of the truck. I just need to find out how to re-do it properly.
Greg
Old 04-15-2009, 08:53 AM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
you can search, and you can also visit your local paint supply store. Wire wheel the drip rails really good, take care of any rust issues at the seams. you will want to use a good self-leveling seam sealer. you can post in the paint and body section, or ask your local supplier as i have seen some ppl put the seam sealer directly on cleaned bare metal, and i have seen some ppl epoxy prime, then apply the sealer, then paint body color.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
