Old 04-14-2009, 11:22 PM   #1
greygoose
greygoose's Avatar
Budget junkyard stuff
I want to do a few things to my truck,like put an electric double fan on it....A friend that I was talking to the other day and I told him I wanted to put a serpentine belt on it too and he told me that I should be able to get an serpentine setup from the junkyard as well,but he didn't know from what.If anybody out there that knows what I'm talking about and could help I'd really appreciate it alot .Thanks
If it ain't a chevy,I don't want it
greygoose is offline   Reply With Quote
Old 04-14-2009, 11:27 PM   #2
spinning wheels
spinning wheels's Avatar
Re: Budget junkyard stuff
Just off the top of my head, I can think of the Chevy Caprice (cop cars, aka Shamu), or the Impalas. The rear wheel drive, not the front wheel drive versions. They have the dual electric fans and serpentine belts. I think the civilian Caprice had one electric fan, not sure if they upgraded them to dual later on.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 04-14-2009, 11:38 PM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
I have the serp. setup from a late 80's S-10 w/ the 4.3 V6. Everything bolts up just fine. However, you'll need to buy a delete pulley in place of the smog pump, which is only available @ GM for about $60. I've heard some of the late 80's C/K trucks and some Astro panel vans with the 4.3 came without the smog pump, but I've never seen one. Also, if you are not running AC- you can also get that delete pulley from NAPA for about 28 bucks.
I don't have any suggestions on which vehicles you can swap a pair of electric fans from.....I just run the stock clutch unit and haven't had any cooling issues.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 04-14-2009, 11:40 PM   #4
greygoose
greygoose's Avatar
yeah the impalas and caprices have them and that is what I have but to make them work would require a lot of fabrication because the fans are a little to big to go side by side....I wonder are the newer van fans,electric fans?My thinking is that they would be electric,because of the limited space.
Old 04-14-2009, 11:42 PM   #5
greygoose
greygoose's Avatar
Thanks for the advice Dingfodgy,no cooling issues either just like the look and it makes it a little quieter.
Old 04-15-2009, 12:11 AM   #6
spinning wheels
A lot of the front wheel drive cars use electric fans, due to the engine layout.
I have seen some nice dual electric fan setups, but I think you would have to find out how much CFM the fans put out. I have owned two '85 Toyota Camrys with dual fan setups and they are narrow. However, they are designed for a 2 litre 4 cyn engine. How much CFM would a V8 need under hot summer day? You might rethink the dual setup and go for a large single fan. Just IMHO
Old 04-15-2009, 12:25 AM   #7
Skirkpat
Skirkpat's Avatar
I believe two small fans will outperform one large fan, the same reason two small intake valves will outperform one larger one, more flow thruogh more opening.
Skirkpat is offline   Reply With Quote
Old 04-15-2009, 12:43 AM   #8
mr48chev
mr48chev's Avatar
If you go to a serpentine belt system you have to get the correct water pump also. The serpentine pump runs in reverse to the V belt driven pump. This usually causes problems when a guy buys a late engine and installs it in an early truck and uses V belts instead of the the Serpentine belt that originally came on the engine.
I first ran into the problem with a mid 80's Camaro that someone had swapped an older 350 with V belts into and then bought a water pump to fit the year of the car instead of the engine and belt combination in the car.
As for the electric fans, look at late 80's and later front wheel drive Cadillac big cars. I've got an 88 with a pair of fans that really pull some air and they are the thin design.
Old 04-15-2009, 08:10 AM   #9
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey greygoose,
look at this thread...not sure if it'll work for a serp setup, but click on the link in the first post for a good electric fan setup...http://67-72chevytrucks.com/vboard/s...d.php?t=286370
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-15-2009, 09:03 AM   #10
my67chevytruck
Under Construction
my67chevytruck's Avatar
bunch of serp info here:
http://67-72chevytrucks.com/vboard/s...d.php?t=233335
I used a serp setup from a '94 suburban. you could use suburban /truck. bolted right up. you do need a reverse water pump, and the '94 water pump bolted right up as well. you can view my build thread to see it installed on the '67
good luck
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-15-2009, 02:32 PM   #11
Dingfodgy
Dingfodgy's Avatar
Pics of my setup for "71meangreenC10"
Old 04-15-2009, 06:01 PM   #12
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Looks good.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-15-2009, 06:57 PM   #13
Sammy
You will also need a different upper rad hose. And a swivel 360 thermo housing. Upper hose get that new for a GMC 94 4 WD hose upper will work.(maybe other vortec/ serp v-8setups too) Maybe issues with power steering pump lines because of the o fittings.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-15-2009, 07:07 PM   #14
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I heard the fans from grand cherokees work great I was hoping to hit the bone yard with a ruler to do some checking...it came from a good sorse and it makes sence most are V8's
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-15-2009, 08:50 PM   #15
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Jeff/Hottrucks...
Look at my post #9 above and click on the link....it is a how-to for installing a jeep cherokee electric fan....A REALLY good source!!!LOL
Geoff with a G
Old 04-15-2009, 10:24 PM   #16
Bpokey
Bpokey's Avatar
I used dual fans off of a late 90's Taurus. They are very plentiful in junkyards and I paid $30 for both. I had my brother in law bend some sheet metal to make a shroud. I also grabbed a few relays out of the Taurus and with a thermal switch for about $15 set it up to turn the fans on at 195 and off at 180. You can also set them up to run both at high speed when A/C is on. These Taurus fans are dual speed and pull a bunch of air. I have had no problems with overheating and I am in Florida. The serpentine setup is off of a 1990 chevrolet 1500 5.7.
Bpokey is offline   Reply With Quote
Old 04-15-2009, 10:46 PM   #17
greygoose
greygoose's Avatar
Thanks guys for the help,from read all you guys post ,kind of makes me feel like a shade tree pro lol.Dingfodgy where did you get that pulley from to replace the ac compressor,mine doesn't have an ac either.
Old 04-16-2009, 12:57 AM   #18
tucnnuts
if they can make it so can I!
tucnnuts's Avatar
i used the dodge intrepid v8 fans pretty thin. i think the over all is like
14"x27"x3.5"
tucnnuts is offline   Reply With Quote
Old 04-16-2009, 03:29 AM   #19
tdave00
Restoring a 68 SWB
tdave00's Avatar
5150 used dual fans from a Camaro and they fit and look good. PM him for more info.
tdave00 is offline   Reply With Quote
Old 04-17-2009, 08:07 AM   #20
firedog
firedog's Avatar
i mounted a electric fan out of a mid 90s firebird right into my factory shroud you wouldnt even know it was there with out looking close i am also running a serp setup off of a 4.3l temp stays right around 180 with my 4 core radiator all the time
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
