Flex Fans
What type of flex fan do i need?
i want a flex a lite from summit but i have a 454 and i need a fan do i get clockwise or counter clock wise and should i get a mechanical or clutch?? Thanks.. |
Re: Flex Fans
thanks ahead guys!
The Older Generation
Re: Flex Fans
Not to be a negative but I just took my flex fan off and took it over to the scrap yard and traded it for a stock type clutch fan. It had all kinds of small cracks in the blades and I could just see it coming apart and going through my newly painted hood. It was on the truck when I bought it so I don't know what brand it was or how old it was but I would just say "no" to a flex fan... Just my 2¢ worth. Oh, and welcome to the board... ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-15-2009 at 08:54 AM. |
Re: Flex Fans
So which fan would you recommend out of summit racing?
Re: Flex Fans
I'm not familiar with their products but I'm sure some other board members will chime in on it today.
LockDoc
Re: Flex Fans
You`ll be advised against these.Basically,flex + metal = fatigue.They definately have a safety lifespan and routine inspection is required.
I started using them thinking I was buying something to outlast a fan clutch when my first one went up.And,it was "Speed Equipment",right?Well,ans don`t run your motor so speed ain`t got neffin tdo wit it.A quality clutch and as big a fan with as many blades is best.I believe there are performance clutches that free up better than oem,allowing a bit more power.You`re best off measuring your shroud and/or stock fan and go hunt the junk yards.
Between Trucks...
Re: Flex Fans
I have a nylon flex fan that was on my truck when I got it. Works great. I wouldn't run a metal flex fan after seeing pics of blades going through peoples hoods.
Beat it to fit, Paint it to match... ![]() |
"the other guy"
Re: Flex Fans
i have personally had a blade come off and go through my hood on two separate occasions, through a steel hood. strange thing about it was both times they shot straight up! never found the fins either! these should be banned! don't use them PLEASE!
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Flex Fans
Another strong "NO" on flex fans. I once had a problem with my OEM clutch fan, so I installed a flex fan. It was the only time (in 3 decades) that my truck ran too hot. Fixed my clutch fan and no more overheating.
BOHICA
Re: Flex Fans
I am probably the only one here to tell you to stay away from clutch fans...well not all of them. Look for a good aftermarket clutch w/as many blades as possible if you want to go that way. I would stay away from the cheap metal flex fans as well. I am looking for a solid poly fan like they have on some of the new trucks, and the first gen hummers. Now the reason I don't like clutch fans is because a brand new one (bought from a chevy dealer) cost me a freshly rebuilt motor about a week after I bought it. So I now only run solid fans. Sure it makes a little wind noise and costs you a couple horses, but you never have to wonder if that clutch is actually working.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
Re: Flex Fans
Thanks for all the info.. i dont have a shroud yet so i can pretty much choose any diameter but which direction should i look at counter clockwise or clockwise
Re: Flex Fans
Since summit mainly has flex-a-lites i am most likey going to go with a fan out of LMC truck but only the 6 blade 18'' shows only small blocks....will these fans hold up to the 454?
#13 |
BOHICA
Re: Flex Fans
If I remember correct, I think counterclockwise is for serpentine setups on some of the newer vehicles. I'm sure someone else will be able to give you a definite answer.
#14 |
What?
Re: Flex Fans
My vote is for the clutch fan setup, and a solid no on flex fans. If you are against that, then think about an electronic setup. Just my .02
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#15 | |
Re: Flex Fans
Of course, an electric fan setup could be the answer too.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#16 |
Farm Truck
Re: Flex Fans
electric all the way
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
#17 |
its all about the +6 inches
Re: Flex Fans
nuff said
#18 |
Re: Flex Fans
Jthornton, I have an 18 inch 7 blade fan out of an early 80's junkyard camaro with a heavy duty clutch bolted to it. The truck has the normal belt setup so it spins counterclockwise and fits right into the stock fan shroud opening, which I measured at 19.5 inches.
Truck came with a flex fan, and by the time I took it off it was on it's way out. Wouldn't recommend them. I won't even give my old flex fan away in case someone catches a blade in the side of the face while setting the timing or something. Side by side ![]() New one in the truck. ![]() Last edited by Indyuke; 04-15-2009 at 07:47 PM. |
#19 |
One of the First
![]() Join Date: Jan 2000
Re: Flex Fans
I guess the next question is; are you looking for an original set-up, Good clutch w/fan and shroud? Do you have the correct pullies, water pump, etc... I'm pretty sure some one on the board has one, in there storage area.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 04-15-2009 at 08:24 PM. |
#20 |
if they can make it so can I!
Re: Flex Fans
