Old 04-15-2009, 12:07 PM   #1
gotmud
gotmud's Avatar
TH400 Dust Cover Fix not right...grind it?
I couldnt find a dust cover for my tranny in the junk yard so I bought one from Summit Racing. It doesnt fit right but I can tell that it should. Seems the cut out for the rms isnt deep enough. Anyone see a problem with taking a grinder to it?
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 04-15-2009, 12:13 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: TH400 Dust Cover Fix not right...grind it?
No Problem - I spent an hour grinding mine - not impressed with the fit on that part
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 04-15-2009, 03:26 PM   #3
sleepertruck72
sleepertruck72's Avatar
I had to cut mine to fit. Its for a 700r4 but the starter was not letting it clear. I cut it, and it fit fine afterwards.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 04-15-2009, 04:23 PM   #4
Green Machine
Green Machine's Avatar
Does you engine have the one piece rear main seal ? The older covers for the two piece seal will need to be cut to clear, ran into this problem before. Our 1988 C1500 has a one piece seal and a TH400, that would be a direct fit if you are having the one piece seal size problem.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
