how many volts does the choke
how many volts does the choke need to receive to work correctly? i'm only getting 2.5-3.0 volts and it kinda acts like it stays on.
Re: how many volts does the choke
+12 volts
Right on the line, baby!
Not sure which year you have, but in mine, the choke is on the same circuit as an oil temp or pressure sender. (It needs to be on a switched power source.)
Sometimes the choke goes, and sometimes its the sensor that's messing up the components downstream. This is way ahead of where you are now, but if find the power source is hosed and you don't want to play detective with the harness, the windshield wiper motor is switched power.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
someday it will be done!
mine reads 12+.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
thanks guys my old truck ran with 12 volts i was just checking. what happened i got my new engine (383) put in and i had some aftermarket gages put in also. they cut the wire to the oil sending unit and my choke light stays on and since then the choke had stayed on too.
Bingo.
12 volt battery thats it everything in your truck runs off 12 volts it's the amperage thats the difference thats what your alt takes care of.
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside ![]() If it ain't a Chevy it's foreign ![]() http://hotridesmag.com/ |
