04-15-2009, 10:03 PM | #1 |
frame swap
Was just woundering if a 73-87 swb frame will swap on a 67-72 chevy swb 2wd...does any one know
04-15-2009, 10:34 PM | #2 |
Re: frame swap
I have a 70 GMC with C10 front fenders on what appears to be a mid 80's frame. I don't know for sure on year of frame, but it is not a 67-72 frame.
The core support mounts are too far forward and the bed mounts have wood between them and the bed (to match cab to bed?) I would say it is doable, but you would need to spend some time relocating the body/core support mounts to end up with a quality job, unlike this truck I bought for parts. However, if I were you, I would look for a correct year frame. P.s. I have a Swb 2wd frame with 6 lug setup and drum brakes front and rear I am planning on selling. You can PM if interrested. It is located in Red Banks, MS (near Holly Springs) about 40 mins from Memphis, TN fyi
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 Last edited by BP68; 04-15-2009 at 10:36 PM. Reason: added info |
04-15-2009, 10:46 PM | #3 |
Re: frame swap
No it ill need a body lift and will lok strange
70 SWB STEPSIDE 70 BLAZER 09 challenger |
04-15-2009, 10:48 PM | #4 |
its all about the +6 inches
Re: frame swap
the truck frames won't work. They have the bed kicked up where you need a flat frame. Plus, you'd need to shorten the wheel base. A burb frame is flat and doable, but still a bunch of work.
