Old 04-15-2009, 11:35 PM   #1
chas350
Moraine or Bendix?
On say a 71-72 truck with power brakes/front disc.
Are there any advantages with Delco Moraine style versus Bendix master cylinder/booster?
I would like to hear any pros-cons if any.
thanks
chas
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 04-18-2009, 10:05 AM   #2
chas350
Re: Moraine or Bendix?
ttt
Nobody know the the difference?
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 04-18-2009, 10:13 AM   #3
leddzepp
Moderator
leddzepp's Avatar
The only difference I am aware of is the color of the booster. The Delco Moraine is gold cad, and the Bendix is black.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-18-2009, 10:17 AM   #4
mbgmike
Hey Charles
Aside from the fact that the same part number on a Bendix was used on more model years then the Delco and the Bendix was black instead of gold I do not know of anything. There really is not much to a booster. I don't think one was better than the other.
mbgmike is offline   Reply With Quote
Old 04-18-2009, 10:20 AM   #5
chas350
I think the shapes are a little different. Are they inter-changeable with each other? I though I remember hearing they werent, but would like the low-down on them.
I have also seen some smaller diameter boosters, what brand/type are those?
Are they only for disc/disc?
come on, somebody educate me!
chas
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 04-18-2009, 10:22 AM   #6
mr48chev
mr48chev's Avatar
Not advantage or disadvantage as far as I know but you need to know but you need to know what you have to match the master cylinder to the booster.
I never figured out the reason for two brands of units except maybe they were installed in different plants or it was what the purchasing dept got the better deal on at the time.
Old 04-18-2009, 10:29 AM   #7
mbgmike
chas
Yes shapes are indeed differant. The Bendix has 3 indentations on the front
D-M has 8
They should be the same. We sell reman ones from Cardone and they are the same pattern from 1971-72. Thats the ones we have in stock
A smaller diameter can be a single diaphram or a dual. Usually the smaller single is used on lighter weight vehicles is all. They come in alot of brands.
A dual give alot more pressure cause what leaks by the first diaphram the second will catch it. Used in heavier vehicles
A booster does not care if disc or drum brakes They do the work on both.
Old 04-18-2009, 10:30 AM   #8
leddzepp
Moderator
leddzepp's Avatar
The 1/2 ton boosters are more flat and have a larger diameter. The 3/4 ton boosters have a smaller diameter and look "fatter"
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-18-2009, 10:37 AM   #9
mbgmike
Yes and the 3/4 ton were also used on the 1 tons as well. I would send pictures but camera dead
Old 04-18-2009, 01:21 PM   #10
tripp
They are not interchangable. The bolts on the back of the Bendix are 3 3/8" across and the Moraine is 3 3/4" across. I didn't know this until I tried to swap them on my sub this week. The master cylinder is interchangable. Measure the bolt spread on the back of your booster and that will tell you what you need.
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 04-18-2009, 01:32 PM   #11
mbgmike
I will need to do some more checking. We have both here and they measure 3.3/8" Not trying to dispute you or anything
Old 04-18-2009, 02:09 PM   #12
mbgmike
The 3/4 tons boosters are 3.3/4in apart. I was under the impression that only 71 and 72's came with Delco Morraine with disc brakes and earlier years were Bendix but I just now took an old Delco off a 70 drum brake truck. We only sell reman bendix for 70 and older but the Delco are only listed for 71 and 72.
Damn now I am getting more confused.
Old 04-18-2009, 08:35 PM   #13
chas350
3/4 ton booster is different than 1/2 ton?
good info here, keep it going!
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 04-19-2009, 11:06 AM   #14
mbgmike
I found this today after doing some surfing. Its from one of our own.
http://outintheshop.com/brakinfo.html
Old 04-19-2009, 10:58 PM   #15
chas350
Excellent! Thanks Mike!
Very informative. All you need to know.
chas
quote by LEEVON
70 K20 long fleet
98 G3500 work van
