Old 04-16-2009, 12:45 AM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
Body Mounts?
Somebody was telling my pick up needed new body mounts because, well, this picture:
What do you think?
One last part,
The driver side door sags. I believe it needs new hinges, will that help? Also where is a good place to order them from?
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 04-16-2009, 01:14 AM   #2
mongoose
mongoose's Avatar
Re: Body Mounts?
most of it is just frame flex?.... 10 foot long c-channel frames tend to do that.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-16-2009, 01:14 AM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Body Mounts?
I would look under the truck and see whats going on. I thought when the body bushings went bad the cab sat lower than the bed. Almost looks like the cab has a small body lift...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-16-2009, 01:27 AM   #4
enaberif
Re: Body Mounts?
Absolutely.
Park the truck level and watch what happens.
enaberif is offline   Reply With Quote
Old 04-16-2009, 11:03 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Body Mounts?
to determine if you need body moumts you need to look under the truck.... it is prolly frame flex like another poster said but if the nose and cab are on an angle to each other its usually the front cab mounts and if the back of the cab sits real low when parked on level concrete, then you can look into the rear body mounts on the cab... that is on dirt and it looks like it is far from level
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-16-2009, 03:59 PM   #6
Damien
Damien's Avatar
Re: Body Mounts?
You can replace the hinge pins and bushings. Your local parts store will probably carry them.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 04-16-2009, 05:51 PM   #7
Prerunner1982
Prerunner1982's Avatar
Re: Body Mounts?
That is just frame flex as previously mentioned...
Mine did the same thing but levelled out when on flat ground.
frame flex..
no flex..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-17-2009, 09:44 AM   #8
Benelli
Benelli's Avatar
Re: Body Mounts?
So, from these pictures, it does not need them?
Only thing I believe I believe I need is door hinges to stop the hanging door.
Old 04-17-2009, 10:55 AM   #9
Prerunner1982
Re: Body Mounts?
from that pic it does look like it needs rear cab bushings.. the trim on the back of the cab is slightly lower than the bed. However fixing the door may not make this as noticable. Replacing the cab bushings on something this old is always a good thing. Mine could have used it, but thats not what is causing the problem with flexing.
Jon
Oklahoma Roll Call
Old 04-17-2009, 05:02 PM   #10
Benelli
Benelli's Avatar
Re: Body Mounts?
Alright.
I'll look into the cab bushings. Part time kit, Door, Cab bushings, X-pipe...... and she'll be almost good as new.
Old 04-17-2009, 07:13 PM   #11
Prerunner1982
Re: Body Mounts?
Originally Posted by Benelli View Post
Alright.
Sounds like a plan... keep us updated.
Jon
Oklahoma Roll Call
