Old 04-16-2009, 10:50 AM   #1
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
question regarding new clutch master cylinder
I am in the process of gathering parts to convert the front crossmember on my 61 Chevy over to a 78 chevy. It all seems to look fairly straightforward, but i'm getting hung up on one issue.
The stock setup on the 61 is a combined clutch/brake master cylinder. When I perform this conversion, I will be going to a dual brake resevoir MC. Has anyone found a replacement clutch master cylinder that will work? It also looks like the clutch MC would need to be relocated, as the new brake MC would be in the way.
For the record, I am running 1962 235 out of a 62 Impala, with the original truck 4 speed saginaw with hydraulic clutch. I know I will need to fab up motor mounts, not worried about that. The clutch has me a little bewildered.
Thanks in advance.
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 04-16-2009, 01:02 PM   #2
joe231
joe231's Avatar
Re: question regarding new clutch master cylinder
here is one option
http://www.classicperform.com/Store/...T6062BB28D.htm
bit spendy though, $450
CHEVY ONLY
Old 04-16-2009, 01:12 PM   #3
Eagletucky
Eagletucky's Avatar
Yeah, thats more than I paid for the whole truck, but at least i have an option. Thanks alot!
Old 04-16-2009, 05:25 PM   #4
slepysal
slepysal's Avatar
I'm going to be swaping to a dual resivour master cylinder soon.
Like your 61, my 60 has the same set up. What I am going to use is a Willwood clutch master I bought from MP BRAKES. It came with a braket that mounts to the fire wall,a new push rod and instructions. Basicly you drill a 5/8 hole , get rid of the old clutch linkage and attach the new push rod to the cluch pedal.
I wont be able to do this for a bit , but will post pics.
Oh and yea that CPP set up is expensive. I paid about 85.00, but if you are handy you could make your own bracket. Hopes this helps
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-16-2009, 08:07 PM   #5
TR65
TR65's Avatar
Hey Tucky,
I had to add a hydraulic clutch for my LS2 swap. Here is a link to the way I did it with an inexpensive Willwood unit like SlepySal. Hope it helps some.
http://67-72chevytrucks.com/vboard/s...d.php?t=300087
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-16-2009, 11:27 PM   #6
Eagletucky
Eagletucky's Avatar
Definately a BIG help, thanks alot for the info!
Old 04-17-2009, 12:13 AM   #7
slepysal
slepysal's Avatar
nice job TR65 !!
Old 04-21-2009, 02:38 PM   #8
soba_03
soba_03's Avatar
CPP 599 and about the only way to go....
soba_03 is offline   Reply With Quote
Old 04-21-2009, 02:42 PM   #9
soba_03
soba_03's Avatar
DANG tr65, I feel like I need to delete my post about my store bought unit after seeing your thread. Nice job for sure.
Old 04-21-2009, 02:56 PM   #10
slepysal
slepysal's Avatar
The ony problem with the CPP unit is the clearance .I dont think it will clear with my 250 cliford intake. How much room between the booster and airfilter ?
Old 04-21-2009, 03:02 PM   #11
soba_03
soba_03's Avatar
Sal,
I'll measure it for you tommrrow, How wide is your intake, it is a single carb intake? Or dual?
It sits quite a bit higher than the intake manifold. I'll measure and try and get some pic's so you can make an informed decission.
I've added some other pictures that might help until I get some measurements. Do you have a measurement as to how far out your manifold sits? Does it look anything like the OFFY dual intake on mine?
Old 04-21-2009, 03:31 PM   #12
slepysal
slepysal's Avatar
Thanks Soba_03 I am running a single 2bbl holley on a clifford intake
Some mesurments would be great !!
Old 04-25-2009, 10:54 PM   #13
slepysal
slepysal's Avatar
just finished my clutch master works goodr I will do a post latter
