Another Cab Swap Question
I did a search the other day and couldn't find an answer.
I am wondering if I will run into any problems swapping the cab from a 3/4 ton to a 1/2 ton frame? And what solutions there may be?
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Another Cab Swap Question
the only problems that arise are when you go from 2wd to 4wd with the floors and if you go from 73-80 and 81-87 with the mounts... you have to use the mounts compatible with the year of the frame and issues with the hood hinges , cowl and wipers other than that its direct swap
i beleve there were differences with cabs when it came to the bigger trucks tho which do not have the proper clearance for the gas tanks on a pickup and i mean the bigger trucks like the c50 and up
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 04-16-2009 at 12:59 PM. |
Both cabs are 74s. So I just use the body mounts for a 3/4 ton when I put the cab on?
I dont think you will have a problem it should all bolt up. The problem is when you start putting 73-80 cabs on 81-87 frames and vise versa. In your case I think the bushings will be the same as well as the cabs themselves.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 04-16-2009 at 05:15 PM. |
